Consensus on aluminum radiators
turbotim2
____________
After reading a bunch of posts, it seems like the consensus is to stay away from aluminum radiators?
I am ok with copper/brass, I am still running a stock 3 core in front of a mildly built 351.
Considering a change during tear down later this year.
BroncoJimbo
Long-term owner
North GA
I've been using them but only due to the cost of a new copper/brass. They are pretty, fit reasonably well but, don't last very long.
AZ73
They don't do well with any kind of flex. Copper is more forgiving when flexing. In the old days aluminum was lighter and more efficient so people used them to save weight and keep cool. Nowadays most copper radiators are "desert" radiators. More fins. They're heavier but similar efficiency. Plus you can braze them anywhere. You get a leak in Aluminum when you're out on the trail and there's no repair.
ntsqd
heratic car camper
Upper SoKA
I recall a post here about comparing the thermal efficiency of the two different types. By itself aluminum transfers heat better than copper or brass does, but the solder used on copper to assemble the whole radiator is better than the braze used to assemble an aluminum radiator. The net result being that their overall actual thermal transfer rates are about the same.
Aluminum corrodes easier than copper, and it can set up a bad galvanic corrosion "battery." Many here have had this occur. Some were able to solve the problem, others who did exactly the same thing were not able to. I've concluded that the OEM use of plastic tanks is not simply a cost based decision. It is also driven by Engineering dielectric needs.
Galvanic Corrosion Link
Just now, really looking at the link I realized that AL is "less Noble" than iron where copper is more "Noble." What this means is that with an aluminum radiator it is the galvanic corrosion focus, but with a copper/brass radiator the iron block & cyl heads are the galvanic corrosion focus. Explains to me why rust on an AL radiator system is far less common, IME, than it is in a copper/brass radiator system.
bigmuddy
Marthasville Missouri
This wasn't the thread that I said I would post this too as I can't find it, but ntsqd I had said I would post this cap and lanyard type anode. Probably going to stick it in several threads for posterity, and I haven't checked to see if they are still available for sale?
Timmy390
Conway, AR
I have to disagree......way too many factors to say "stay away from" All OEM rads are plastic and aluminum and have been for many many many years.
Now the issue with Bronco rads is the vast different way Broncos are used. I can tell you my drive it hard all the time on the street bronco that looks VERY offroad capable (some would call it rough) has had 2 aluminum rads in the past 10 years. First one was name brand. It leaked from day one of install. The leak got so bad I swapped it out in a pinch with a cheap eBay aluminum rad. It's been 2 or 3 years now with no issues. Keeps my mild W cool and no leaks. I'm happy with it. When it fails I will order another. OR maybe I'll do the Explorer rad swap. They're cheap and parts stores have them.
For street use IMO aluminum is fine. For hard offroading maybe not.....but maybe so. Offroading is a relative term.
Tim
bigmuddy
Tim
Good points, there is a local buddy that has killed several aluminum radiators and finally after speaking with one of the manufactures came up with a different mounting system that allowed more rubber isolators and to accommodate more flexing when offroad. He hasn't had any issue again since going to a this different and more flexible mounting system.
toddz69
Lawndart
Al gets a NO vote from me.
Spent a bunch of $$ on a nice Griffin, fittings for the trans cooler, etc. Leaked within a year.
Back to a original reman from Orielly's... 50k miles later and no leaks.
ntsqd
heratic car camper
Upper SoKA
Just take your stock one to a reputable local shop and have em put a good quality core in it
In my area that is a challenge all by itself. Most of them have closed.
Semi-related: Heater core in Snowball died on the way to work this morning. That is the second one I've put in this truck since buying it in '19. Aluminum cores appear to be the only option. Tempted to try the $100 FoMoVo option if it means that I don't have to do this again. Time for a coolant service anyway....
Timmy390
Conway, AR
How about this one?
https://tomsoffroad.com/products/66...gBMUuFMondi3ufIc_a7deJUPyaqnZP7kaAsGFEALw_wcB
Or
https://www.jegs.com/i/JEGS/555/760...LriEji7RBlPiUb8ETmSylqycgWgn8WL4aAquwEALw_wcB
Tim
ntsqd
heratic car camper
Upper SoKA
[HIJACK]'96 MY, would need this one: https://www.jegs.com/i/JEGS/555/76062/10002/-1?year=1996&make=FORD&model=BRONCO but its AL and suffers from what I'm beginning to think is a design problem that all of them have. Note how the tubes on it are connected to the end tanks.
Compare/contrast that with the FoMoCo core here: https://www.npdlink.com/product/heater-core/130372
There is nothing that really supports the tubes when you're pushing the hoses onto them, or supports them while in use. Last two both failed at one of those connections, am betting this one did too.[/HIJACK]
Timmy390
Conway, AR
Yup....my tubes broke when taking the hoses off. In Arkansas I don't really need a heater so it's been disconnected for years. Not having a defrost is a pain si I carry a shimmy to wipe the windshield.
Tim
Aluminum can live. They key is mount them so the float. Mount rigid, they flex, they will fail. Brass will as well but generally takes longer. Any modern aluminum radiator is mounted is squishy rubber. Body can flex, radiator does not.
Epoxy where the tubes meet the header was frowned upon. But is generally a good idea. The actual seal is done by brazing, the epoxy is a strain relief at the joint.
top and bottom headers sawn is a good thing. They expand at different rates than the tubes. The cut lines remove the stress where the tubes meet the tanks
