Show Links
I'm currently running a stock cap and rotor on my Duraspak distributor which has the traditional female socket brass terminals and side clamp-downs. I'd like to convert the cap and rotor to male HEI type terminals. Specifically, I was thinking of purchasing the following, which is available from Summit:
* Davis Unified Ignition 32100BL - Davis Unified Ignition Cap and Rotor Kits. Cap & Rotor, Blue, Male/HEI, Brass Terminals, Clamp-Down, Ford, Duraspark, Big/Small Block, V8, Kit
Does anyone know if this conversion is a straight swap with my stock cap and rotor on my stock Dura Spark distributor and is there room for the larger cap and Rotor.
Thanks for any help.
Rob
Rob
