you are looking for the most bang for the buck, or simply the best period? Look at the # of fins per inch and the width and number of the cooling tubes. If it's copper/brass then take this for gospel that this your cooling area. Then if it is aluminum divide the number they give by about 1/2, then you are comparing apples to apples. Aluminum is roughlyu 1/2 as efficient at conducting energy as copper. Thats why you don't see aluminum wiring in houses anymore.(electrcity and heat, both energy) Oh yeah, electrolysis sets in quickly too with an aluminum radiator (dissimilar metals) so be ready to change your coolant often if you want it to last. I hope this helps. good luck!
