Timmy390 - I read your thread on the cracked head and it made me so sad for you all that work over and over again.
Don't you need sealant on some of the bolt threads (those that go into the water jackets) and not just torque lube?
Thanks for the kind words. Don't feel sad for me.....it was just one of those things that sometimes happens. I posted all the info I could to maybe help a Bronco Brother in the future if they have issues. I did get a set of GT40P heads built for a song out of the deal.....
As for sealant.....my build was a 351W. Due to the W's taller deck height none of the head bolts go into the water jackets like on a 302. I double and triple checked mine due to all the "yes they do and not they don't" statements out there. Mine were as blind as the three mice so just lube was used.
Now I will say it's possible to have the bolt holes crack into the water jacket if the wrong bolts are put in i.e long bolts from the top installed in the bottom and tightened you could bust through. Also if someone runs the bolts down without the head on and bottoms them out.....
But in stock unabused form, my 96 roller bock had blind holes....
That said, you need to use sealant on the threads of a 302. I'm not sure if all of them go into the WJ or just the lowers.
Tim
