DanWheeler
this pic shows the passenger side going to the pump
Hey Dan,
I have been following Nightstick's thread, which pointed to yours.
I am confused by a couple of things...
1. I have an existing power steering pump (probably from a late Early Bronco). I bought a rebuilt Saginaw to replace it with during the Hydroboost project. Do I need a different pulley, or can I reuse the original? (I hope that isn't a stupid question to ask.)
2. The Bronco has a manual brake system. Do I need to use a different master cylinder and reservoir, or can I use what I have? (I also saw your statement about a new proportioning valve.)
Thanks for any advice you can offer.
Jeff
Hey,
Thanks again for the input.
I measured the shafts, and like was posted by another member (one of you guys, maybe), the shaft on the stock pump is slightly less than .70". The shaft on the Saginaw is .75".
More trips to NAPA and AutoZone for a new pulley and a pulley installer.
I am hoping my auto shopping runs are over for the weekend. If I get everything installed with the exception of the high pressure hoses, I will probably have them made at NAPA on Monday unless it is a lot less expensive to do it myself.
I didn't want to get started and then need to make more runs... I sure hope I'm good to go.
Thanks again.
Jeff
Do you have the fittings for the h-boost input and output? they are metric bubble flare and NAPA may not be able to make hoses that work with metric bubble flare. There should be a parts list on page 1 of this thread that lists the fittings you need to convert to AN. But then NAPA may not be able to make AN hoses - they probably just make inverted flare hoses.
Hmm sorry Jeff, I'm a little out of my element now... I've only done one of these boost setups so I only know how mine works. I thought the Saginaw canned ham pumps were either 16mm bubble flare or 3/8ths inverted flare for the output. My Saginaw (when I had it) was 3/8ths inverted flare. I used a fitting to convert the output to -6an.
7/16ths sounds more like the steering gearbox IIRC. Should be listed on page 1. I would recommend using fittings to convert all your high pressure inputs and outputs to -6an then make your own hoses with the Russell powerflex stuff which is specific for power steering and rated to 2000psi. PM me if you have any more questions then we can switch to email.
Just to muddy the waters a little bit.. I just checked the pressure fitting size on my 4x4x2 box... Its 1/2-20 inverted flare...so I guess some are different.. Check yours before ordering
