DanWheeler
Hi all, I haven't been on here in quite a while mostly because things have been going well and I haven't made any major changes but I'm having some trouble this spring with my EFI.
A while back I moved my TFI to the fender and put it on a heat sink. I did it the ghetto way just using the same TFI and some spade connectors but they are not making a good connection giving me no-start headaches.
I want to move to the "closed-bowl" distributor for a 94 Mustang and I found this old thread:
http://classicbroncos.com/forums/showthread.php?t=197853
but I still can't figure out which TFI module I should be using if I bought this distributor:
http://www.summitracing.com/parts/sum-850410
I have A9P and C3W ECUs. How do I figure out if I want push start (grey TFI) or computer controlled dwell (black) TFI? I have grey now.
I think I can use the diagrams from the old thread to figure out how to run the cables - just need to order the right parts.
thanks!
Dan
thanks!
Dan
