DanWheeler
Fine job Dan !! The only thing I see that could cause a problem is the shock mount being mounted off center as it could cause a twisting moment in the arm itself.
I have F250 shock mounts which extend out away from the frame so putting the shock mounts outside the arm a bit straightens the shock out vertically. Then when the axle at full droop on that side there will be less stress put on the shock bushings.
