Dana 20 shift shaft seal?
Viperwolf1
electron whisperer
It might be easy on a T-shift. If you can get the old one out with the shift rail in place you should be able to get the new one in. Usually replaced after the tcase is completely taken apart.
Shift rail seals-CR #6204, Timken #471466
armynavy17
I had no problems changing them out on my T-shift with the rails still in. Pulled them both out with a dental pick, lubed up the new ones, slipped them over the shaft, and used a deep well socket to tap them in place.
BroncoBrummet
BroncoBrummet
Spring Creek , NV
Awesome, got t case out, gonna attempt it tomorrow! Nothing else is leaking ang t case works great so don't really want to rebuild or totally reseal. Thanks guys
