Definitive answer to lower radiator hose part number for 5.0 swap using 4.0 Ranger/Explorer Auto/AC style radiator
skrit
A Horse with No Name
Durham
Title sums it up. There are so many old posts I have read but none seem to address the lower radiator hose for the 4.0 Auto/AC radiator which has the return port angled down like this:
If there is no molded one that will work without splicing - I guess I will use a Gates Vulco Flex II flexible hose.
1973bronco1973
The hose you mentioned is the best solution I have come up with. I’ve been using that radiator and hose for almost 10 years without any problems. It just doesn’t look as clean as molded hose.
Timmy390
Conway, AR
If memory serves....I think part of the issue is the radiator outlet is smaller than the water pump inlet thus you need a hose with different sized ends.
Tim
skrit
skrit
Durham
That's what I figured I'd end up needing to do.
skrit
skrit
Durham
Tim
I'll measure them this evening to verify.
skrit
skrit
Durham
Yep. They are different. Explorer 5.0 and the earlier 4.0 radiators both have 40mm OD inlets/outlets (measuring including with the raised sealing area) using calipers. The Explorer 5.0 water pump inlet (and the hokey oil cooler filter adapter thing which I'm not using) is 47mm.
The stock lower explorer hose must have 2 different sized ends. Update...Just looked at the specs of one and it does.
skrit
skrit
Durham
So the definitive answer to my own question is... there is no off-the-shelf one piece molded radiator hose for this application. The only options are splicing like @tasker or a Vulco Flex style with 1.5" on one end and 1.75" on the other.
I'm also not aware of how to custom mold a radiator hose with a heat gun, oven, grill, steam, etc without compromising the integrity. Vulcanizing rubber can't be undone and redone (I checked).
So once I verify the length of Vulco Flex hose needed, this case will be closed. Hopefully others in the future will find this info helpful.
