E-brake alternative advice
nickeboy
Due to some mods and upgrades, I cannot use a standard ebrake. I'm thinking of using a hydraulic brake lock system. Mico makes a lever type. Any issues that I may run into? Have any of you done this?
A hydro park brake is no good. the miniscule amount of fluid that actually moves in the lines means if a drop or two leaks back through the valve the brake will release. Don't fool yourself, and those around your vehicle into thinking you have a park brake without a proper cable actuated park brake.
Only issues are that it's not legal as an alternative if you have inspections in your state.
Other than that, I'm certainly no expert but can't think of any real bad things about them. As long as your rear brakes work well, the Mico lock should as well.
Don't substitute it for a good sized rock under a wheel if you find yourself parking on a steep hill somewhere though!;D
Well, I'd go with his statement first. I should have asked if this is a street driven rig and a daily driver. When you said you made mods that precluded a standard parking brake, I figured you had a trail rig.
And speaking of which... Just what did you do?
nickeboy
nickeboy
Hmmm. Ok, I'm going to have to try to reconfigure some things. I want a solid setup. Thanks for the input.
68rockcrawler
The hydraulic 'lock' is better as a line lock for racing or occasionally used as an anti-theft device.
Here is something that I would trust more:
http://www.partsmike.com/index.php/...ake---atlas-and-hd-outputshaft-transfer-cases
I just installed that parking brake last winter so I've only got to test it out a couple of times. Naturally with a Bronco everything about it had to be custom, from the linkage from the cable, to the mounting brackets, to the return spring. I have not tried it to the extreme yet so I can't say whether I recommend it. All I can say is it's a lot of work to put it on a Dana 20. It is pretty simple on an Atlas though since everythign that came with it was for mounting to an Atlas.
00gyrhed
i didn't want one on the floor so I mounted a handbrake horizontally under the dash. I like it but i am the only one in the family that could actually bring it to ta stop. They take some upper body strength.
sykanr0ng
To mount it on a Dana 20 you first put the AA HD rear output on the Dana 20
The AA HD rear output for the Dana 20 is the same as the Atlas rear output.
The AA HD rear output for the Dana 20 is an excellent idea on its own, even without this brake.
68rockcrawler
Oh shoot I see it now. I had their HD output shaft that put in my stock housing. That sure would have made it easier!
Sent from my XT1254 using Tapatalk
bronconut73
Sykanrong, is this kit what I would need?
http://www.bjsoffroad.com/Dana-20-Rear-Output-Shaft-Upgrade-Kit_p_1579.html
I'm pretty sure I have old caddy rear disc brakes. I don't see where I'd hook up any ebrake to it. I'm going to take to a local bronco guy tomorrow to see what his opinion would be. If I posted a pic of the rear end, could anyone help?
It says "WILL NOT FIT FORD DANA 20" in the instructions.
That brake kit said you need the Advance adapters HD output kit.
nickeboy
nickeboy
Anyone know what setup this may be from? It is on a 9" floating 31 spline axle. Better yet, can I put an ebrake on it?
bronconut73
Looks like BC's kit.
You can buy the cables from BC too.
Those appear to be Caddy calipers so you have the internal parking brake mechanism but you still need the exterior bracket and spring.
Just look up the image of a caddy caliper and you will see what I'm talking about.
79-85 Seville.
As stated above, GM metric calipers. Looks like they are park brake calipers just missing the external parts. Unless something changed in the past few years, some of the brackets are now obsolete and you need to find them used.
sykanr0ng
This one:
http://www.wildhorses4x4.com/product/Extreme_Dana_20_Output_System_Complete_Kit_Assembled
or this one:
http://www.wildhorses4x4.com/product/Extreme_dana20_Output_System
are the ones.
pbwcr
I have used the Cad disk brake from BC on my 72. And I have the Varga/Ford on my 96 Both work fine, but are not as strong as the old drum brake setup. Both the above were on 9" with big bearing. Source the Varga from SVT Mustang or the superbird Mustang. I like the varga best.
Cable is no big deal just splice the stock cable to the JY cable that came with the Varga. The BC is a kit and is an easier install.
SteveL
Huge chevy guy
Hawthorne ca
I have the bc kit on a 77 floating rear. They do use the caddy calipers with an e-brake. If u have the correct calipers I was able to buy the parts to hook the cables up at the dealer in a nice kit. I think it's just the bracket ,spring and nut. Bc hat tips for adjusting the e-brake on their site.
