What horsepower numbers are you after? Do you need 24 lb injectors? I think mmost stock 460 trucks are only running 24 lb injectors.
Well of course the answer to question 1 is as much as possible. ;D Total armchair speculation here....but my thinking was that since the 351 is a little bigger than a 302 that it may benefit from the 24lb'ers, 70mm MAF and Cobra ECU. Seeing as how the Mustang stuff(EEC, 19lb, 55mmMAF) was developed by Ford for a 302 engine, I thought this made sense to seek out the next step up. Since I know little about building engines....is my logic here whack? Right now the Lightning will remain stock, other than the MAF conversion, however, I could see a cam change and 393 build in the future. Im trying to get the injection system pieced together once vs. having to change/upgrade it when the changes start.
