EFI fuel issue
BroncoMarc
BroncOhio
I've had a recurring issue with my EFI. I'm running the BC Bronco's accumulator setup. Low pressure pump on the frame rail in back feeds the accumulator under the hood feeds the high pressure pump feeds the fuel rails.
Normally if I toggle my ignition switch a couple times I can hear the high pressure pump load up when it builds pressure. I went on a ride on Saturday and a few times it would not do this and it would not start! If I let it sit for a few minutes it would usually start working again.
I had an issue in the fall when it did this and I wasn't getting fuel into the accumulator. I've replaced everything from the fuel cell to the accumulator to fix this. When it was having trouble this weekend I pulled the line from the back to the accumulator and I was getting fuel.
Right now it's doing this while cold and I can't even start it to get it off the trailer, so it can't be a heat issue. So, What's next? I'd love to put a pressure gauge on the fuel rail to see what I'm getting, but my fuel rail does not have a shrader valve. Do the pressure regulators on the fuel rail go bad? Would it cause this?
rcmbronc
Tomah WI
If you remove the return line from the engine and turn on the key does fuel run? I am wondering like you if the regulator is open not building injector pressure. May also want to pull the HP line to the fuel rails and turn it on to see if the HP pump is pumping any volume.
needabronco
Prescott/Farmington
If you have to toggle the ignition switch a few times in order to hear the HP pump pressurize, I'm leaning towards a wiring issue, check your grounds and check to make sure the positive connections are tight and not corroded.
Your HP pump could also be failing due to heat from being under the hood(initially) and now is completely done... Good luck figuring it out.
Socal Tom
San Diego, CA
Its fairly common to have the low pressure pumps overheat after a day on the trail. Most are designed for part time use filling carbs ( even though they run when the float valve is closed, they don't do any work unless they are moving fuel). When used with an accumulator, they run full speed for hours, and unless you are at highway speeds giving them lots of cool air, they over heat and don't pump fuel.
Tom
Phoenix0783
I would set it up so that you only use the low pressure pump to prime the accumulator after a filter change or something. I have another fuel injected car where I only use the high pressure pump, which is after the accumulator and it runs fine.
Socal Tom
San Diego, CA
reread your post, do you have a fuel filter between the accumulator and the HP pump? It could be plugged, or if you don't have you may have crud in the HP pump.
Its also possible that when you had the issues in the fall, that the HP pump got worked over and now its failing.
Tom
BroncoMarc
BroncoMarc
BroncOhio
I just went out to try pulling the HP line and the return line from the fuel rail, but now it fires right up. Guess I'll need to try it each night till it starts doing it again.
The wiring is ok. Both pumps are running. The sound of the HP pump has always changed around the 2nd or 3rd ignition toggle.
I've got a filter before the low pressure pump, and the accumulator is a huge filter, so I don't thing any gunk is getting thru.
nyhillbilly
Canton, MI
just my 2 cents, sounds like your loosing prime in the system. after it sits for awhile you have to jockey the pump to build pressure. could be its sucking air up at the rail and draining all the fuel back into the tank when not running.
be interesting what it turns out to be
BroncoMarc
BroncoMarc
BroncOhio
Finally got around to messing with this today. It was coming and going, but now it hasn't started in a couple weeks due to this (and a optima that's dying).
I'm really leaning toward a bad regulator. I pulled the line between the high pressure pump and the fuel rail. Flipped the switch on and had plenty of volume come out (at least 75 cents worth). Held my thumb over it and flipped the switch and had plenty of pressure. Also the pump sounded like it was loading up like it is supposed to when it builds pressure. It doesn't do this when hooked up to the fuel rail.
So, I'm guessing the pressure regulator is wide open. It's a used regulator. My buddy works at a salvage yard and gave me this fuel rail with the regulator attached. Actually, it's a 5.0 fuel rail on my 351w. I cut off the tubes between the rails and replaced them with HP fuel line to widen it. Hope there's no issue there. It doesn't leak or anything.
I'll try picking up a regulator this week and see if that fixes it.
brewchief
If you pinch the return line off does it work correctly? This is basicly all the reg is doing, I went to an aftermarket reg that is rebuildable and has a gauge port, I mounted a small liquid filled gauge permently on the reg, it's handy for problems like this.
Brewchief;D
BroncoMarc
BroncoMarc
BroncOhio
Good idea! Didn't think of that. I just tried, but not enough in the battery even with help from the charger. I could hear it building pressure though. I'm going to let it charge over night and try it in the morning.
Where did you get your regulator with the gauge port? Do you have a part #?
bigmuddy
Marthasville Missouri
Mark, I run a cheapy autometer fuel pressure gauge in my hood where I can see it and then got a SS braided line connector that runs from the shrader valve on the fuel line to the back of the gauge. Works great and was really pretty cheap.
Ben
brewchief
I used a BBK reg, BBK-1706 in my summit catalog, for a gauge I used a summit 0-60 psi gauge SUM-800160. I used a couple of 1/8" pipe 90's and a nipple to clear the egr valve.
Brewchief;D
BroncoMarc
BroncoMarc
BroncOhio
Too expensive for me. I picked up an Autozone regulator and it seems to have fixed it. I've fired it up a half dozen times now. I'll have to try it a couple times each day to make sure I'm not back to the sporadic issue.
It sure was a PITA to change. The screws go in from below and there's barely room to get an allen wrench in from below.
I'm going to just get a T to hook up a gauge and I'll put it in the rubber line between the HP pump and the fuel rail.
BroncoMarc
BroncoMarc
BroncOhio
The problems continue. I tried it for the next few days after I swapped out the regulator and it was working fine. The battery was dying on me again so I had it tested and it didn't pass. I just got a new battery and it's cranking great again. But.. It's not starting again!!! Argh!
I put a pressure gauge inline in the HP hose just before the fuel rail. I turn the ignition on and I get 40#. Once it turns the pump off it drops to 0 in a couple seconds. When it's cranking, it's right on 40#, but when I stop it drops right to 0. Is the pressure normal, or should it stay pumped up longer? Seems like if it's getting pressure while cranking it should fire.
72ford
I had a similar problem I ended up changing the ECT sender, I think it was keeping the computer in warm mode instead of cold mode, anyhow my starting problems went away, I also put a inline check valve between the high pressure pump and fuel rail also the ACT sender can give you problems.
ransil
Should hold pressure for a while, last time I checked mine I had pressure an hour after shutting it down.
BroncoMarc
BroncoMarc
BroncOhio
Latest developments - Played with it today. I haven't been able to start if for a week. Ran the codes and just got the standard 81,82,84,85. Check for spark and it lit me up.
I decided to do the equivalent to dribbling gas down the carb. I put gas in a windex bottle and sprayed it in the throttle body. That may have been a mistake. It atomized it well enough that I got a big fireball out the intake and singed my arm hair! But.... The Bronco started!! Now it starts just fine. I've fired up up a half dozen times now and it's running fine.
I suspect in a few days it will go back to not starting again. Last time it wouldn't start I changed the fuel pressure regulator and it started fine for a few days. What would cause this sporadic problem?
Viperwolf1
electron whisperer
If you have an ohmmeter it's easy enough to check the coil. Mine died after 2 days of running. You should have about .5 ohms on primary (between connector terminals, unpluged from harness) and about 8,000 ohms between either connector terminal and the high tension lead. Also make sure the coil is grounded good or it will die like mine did.
