this is what happened.
specs first:76, with fittech, and stock 302,
it has been driving completely fine every day, until today(its my daily driver).
My son and I drive to go get dinner, and we eat and then return to the bronco, and when i put the key in, the starter just keeps cranking over and over, and it wont stop. I take the key out, and it still cranking, and I put the key back in and switch it around from off to on to off to on, and take it back out again and the starter is still chugging along. I then jump out and pull the ground and shut it down. It was turning over the whole time with or without the key being in.
Every time i went to connect the ground wire i would get sparks and the starter would start to kick over and the engine would crank. But never did it actually start up.. just crank and crank....
The only thing different i did today was put the key in earlier that day and turn it to the left to turn on the radio for a bit(i usually dont do this).. But i drove it after that, and then had the startup problem later on..... once and awhile i have problems getting the key in the ignition turning it to the left or right position.. mainly because it feels likes an old key..
So.. I have no idea what this is.. i assume its my key ignition switch internals.. and I just need to buy a new one of those... But is there a way to trouble shoot this before i buy it?
What would you guys do? I cant hook the battery up or the engine just cranks and cranks and I get sparks...
if it is internals in the key ignition switch.is there a way to free up those parts?.. wd40?
as always.. any help is appreciated!!
