Had a crate 302 installed in my '77. Most everything else on it is stock. Was running great for a week, but the ignition switch was sticking and hard to turn. Replaced the ignition (not the entire assembly, just the inner part) and it fired up and still ran well for several days. Went to start a day later and the engine cranks but will not fire up and begins to drain the battery. The wires going to the coil read 12V when the key is turned on. A buddy checked the wire from the ignition coil to the distributor cap by inserting a plug and it emits a blue spark when cranking. A similar test of one of the plug wires produces no or very faint spark. I've replaced the ignition coil and distributor cap and rotor, but it seems that was just a waste of cash. Any suggestions? I'm still thinking I may have issues with wiring from behind the ignition switch, but would I still get power to coil if that was the case?
