Engine will not turn off
DCrews
Went to turn off ign switch, engine kept running. Thanks for any HELP!!:)
After you pull the coil wire, unhook the battery. Just because the engine stops doesn't mean things are actually turned off. It will be like leaving the key in run. Can burn out points, coil, ignition module if left on and not running. Will also suck the battery down.
Then it is probably a bad ignition switch that needs replacment (not the lock cylinder, the switch the cylinder turns)
Any more info you could provide might halp as well.
Have you done any electrical work on it recently? Replaced an alternator or ignition system by any chance? Starter relay? Anything else done recently?
D
DCrews
Drove to NAPA this morning picked up new starter relay.FIXED!!!!! Been restoring my bronco for three years now and its now finelly done. ClassicBroncos.com Forums have really been alot of help over the years. Thanks to all members for there know how
Viperwolf1
electron whisperer
I don't understand how the starter solenoid could cause the problem. Maybe you have some stray current attached to the brown resistor bypass wire on the "I" terminal. If the solenoid was hanging the starter would be constantly running.
The "I" wire is on the contactor plate. This isolates the "I" unless the solenoid is engaged.
If the contactor hangs (welds) on the battery side or the wire breaks loose and reaches the battery side it could force 12V to the "I" without spinning the starter.
rsharpnm
Las Cruces
Wow! I never knew that! I thought for sure it would be the ignition switch; I've only changed starter solenoids when the starter doesn't disengage! Thanks for the tip!
