Thanks all for the help on my previous projects.
I’ve been dreading this one and I finally started it this weekend.
I’m going in to replace the timing chain seal because it leaks a little bit of oil and a little bit of radiator fluid.
While in there it was recommended to me by others that I replace the timing chain set and so other seals and that I replace the harmonic balancer as well.
So we started:
removed the front grill
drained the radiator and pulled it out
removed the belts and fan
unplugged various hoses
pulled the alternator
eased the power steering to the side
disconnected the fuel pump
pulled the harmonic balancer
hit my first snag
would like some advice.
the dampner I took off had a three bolt pulley wheel attached to it, the replacement I bought has a 4 bolt face and is noticeable taller than the one I took off. so something is wrong.
pictures are attached. here are my questions
1) what should I do now?
2) which of these is correct for a 74 ford bronco? I thought I was careful when I ordered the replacement and I wasn’t aware there were 3 or 4 bolt versions and tall and short versions.
3) should I try to re-order a different balancer that is more similar to what i’m taking off or
4) should I try to order a new pulley for the new balancer that is lower profile and has four bolts?
here is a link to a video of what i’m looking at.
https://youtu.be/t9cF8mjlA4U
btw I weighed each of these and the newer 4 bolt one with the raised metal spacer weighs more.. it’s like 10lbs while the one I took off is like 9lbs
yes I think they are both 28oz balancers
ideally i’d like to just go back to mostly stock but i’m not sure what that looks like.
thx
So we started:
hit my first snag
thx
