I got that same fault code P0000 at least one time when I first ran mine. I cleared it and it didn't come back. I never asked them what that code meant. Then I was having ignition issues and got rpm noise code. After I changed plug wires, plugs, distributor cap and rotor, no more fault codes at all. Okay also I was having issues with the factory throttle linkage not getting full movement out of the throttle body linkage. So tonight I ditched the factory setup and installed the BC Broncos throttle cable. I now have complete movement from 0-wide open throttle. Wow what a difference. I was probably only getting about half of the throttle to move before. I was actually impressed with that. This is pretty much amazing. I don't think I've ever hit 4,000 rpm shifting through the gears.
Idling better too, when I could not get mine to idle down it was the secondary throttle plate not adjusted closed. So the idle air motor couldn't do its job. After I adjusted both front and rear throttle plates closed it will idle down pretty quick.
Only problem I had with my handheld unit so far is the little button kept falling off the little joystick. I put a small amout of superglue gel on that and it fixed that issue.
