Got this from Bryce the other day on adjusting the idle.
The TPS reading will zero out every time you key off and allow the EFI save. What you are trying to achieve is to be at idle at operating temp with the IAC position between 5 and 10. To achieve this follow the steps below.
1. Bring engine up to operating temp. (around 180)
2. On the handheld go to Dashboard
3. Observe the TPS, IAC Steps, and Coolant temp readings
4a. If IAC Steps is zero and RPM is above target slowly close primary throttle blade screw (1/8 turn at a time) till IAC Steps start to raise to target 5-10 range.
4b. If IAC Steps are anything above 10 slowly open the primary throttle blade screw (1/8 turn at a time) until IAC Steps lower to the target 5-10 range.
NOTE: If TPS reading is 1.5 or higher the EFI doesn’t think the engine is in IDLE so it will raise IAC as a follower feature. To reset TPS just key off an allow EFI to power off. When EFI has saved the handheld values will go blank.
Bryce Cegielski
FiTech Fuel Injection
12370 Doherty St. Suite A
Riverside, CA 92503
Phone – 951-340-2624
bryce@FiTechEFI.com
