In your pictures, the rear mat section looks to have factory holes for the seat and seat belts. Only the pair of 4-hole squares at the front would have been added later by a PO or installer.
And incorrectly too I would say!
Normally you want a roll bar bolted directly to the metal floor, where they look to have put it right over the mat. It's awkward to cut accurately for a bar and foot plate, but I think that's still the better method.
As for the front, it's hard to tell for certain, but they all look to be factory '73 or later holes.
You can see some of the small screw holes along the edge for the chrome hold-down strips. You can see the four holes for the driver's seat, plus the additional seat belt. And the larger rectangular slots on the passenger side are for the pivoting feet of the seat with their two bolts each. Then the clamp loop hole, plus seat belt holes, etc. Then the oval shaped hole for the J-shifter.
I've never seen a full 1-piece black one in person before, just the 1-piece front in black. But they should all be the same no matter what color they were from the factory.
BTW, are you keeping your mat in the house, or out in the warm sunshine if you have any, before you try to install it? Or at the very least is it all laid out and opening up?
My thinking is that the warm sun would be good for a start, but then once you lay it in the vehicle let it cool a bit after you've initially formed it over the edges. But before you do any permanent cutting, gluing or forming.
Good luck. Can't wait to see pics of it installed. I think it might be a first for me, as others have talked about it here but I don't remember seeing final pics.
