Floor Mat Holes
green61bug
Greensboro
I'm getting ready to clean out the inside of the 1975 and install new dennis carpenter front and rear mats like the bronco came with. I was wondering if anyone can show me pics of factory mats with the holes and how large the holes are? Also does anyone have a suggestion to make nice clean circles in the thick rubber mats?
I did find a couple pics from another thread. Curious on size if the different holes and if you guys know of any that are not factory on these other mat photos.
armynavy17
Best bet for clean holes in my mind would be an appropriately sized punch. Easily found up to 1" and larger, should have no problem going through a 1/4" of rubber.
904Bronco
San Martin, CA
When I was installing a new carpet kit in my 96 Mustang, the installation video on line said use the appropriate sized hole saw, but run it in reverse as to not grab the carpet threads. Go slow and don't force it. It actually worked really well.
Take a piece of electrical conduit and sharpen the edge and put a piece of wood under the carpet and go to hammer town. or take a piece of wire hanger and form your hole size. heat the wire red hot and burn through the carpet seared edged and no fraying just stinks like hell. just have a wet towel near by incase you need to snuff out a flame up.
In your pictures, the rear mat section looks to have factory holes for the seat and seat belts. Only the pair of 4-hole squares at the front would have been added later by a PO or installer.
And incorrectly too I would say!
Normally you want a roll bar bolted directly to the metal floor, where they look to have put it right over the mat. It's awkward to cut accurately for a bar and foot plate, but I think that's still the better method.
As for the front, it's hard to tell for certain, but they all look to be factory '73 or later holes.
You can see some of the small screw holes along the edge for the chrome hold-down strips. You can see the four holes for the driver's seat, plus the additional seat belt. And the larger rectangular slots on the passenger side are for the pivoting feet of the seat with their two bolts each. Then the clamp loop hole, plus seat belt holes, etc. Then the oval shaped hole for the J-shifter.
I've never seen a full 1-piece black one in person before, just the 1-piece front in black. But they should all be the same no matter what color they were from the factory.
BTW, are you keeping your mat in the house, or out in the warm sunshine if you have any, before you try to install it? Or at the very least is it all laid out and opening up?
My thinking is that the warm sun would be good for a start, but then once you lay it in the vehicle let it cool a bit after you've initially formed it over the edges. But before you do any permanent cutting, gluing or forming.
Good luck. Can't wait to see pics of it installed. I think it might be a first for me, as others have talked about it here but I don't remember seeing final pics.
SouthPaw74
South Florida
I used a dremel tool for my holes. Left a smooth,round hole in the mat. The DC mat is a fairly thick rubber that was easier to grind than cut.
green61bug
green61bug
Greensboro
I went ahead with the holesaw method on the mats... It was what I had right here so that made it an easy decision. Worked out nicely! As long as you are slow and steady it cuts smoothly right through the rubber. They definitely aren't prefect but I managed to make it close to a "factory look"
