- Mar 20, 2008
- 1,270
On the original '73 drum knuckles, there is a threaded hole on top of the casting to attach the steel-to-rubber hose bracket, but there is not on the '78 knuckles,. where do I anchor the steel-to-rubber hose junction?
BTW My '76 Ford shop manual reads "install and tighten bearing adjusting nut to 50 ft/lbs, the back off 90 degrees, then install the lock ring (pin into closest hole), then tighten outer lock ring to 90-100 ft/lbs".
I saw in another post about checking "End play" what is the procedure for doing that?
