Front disc conversion from a '78 bronco question
reamer
On the original '73 drum knuckles, there is a threaded hole on top of the casting to attach the steel-to-rubber hose bracket, but there is not on the '78 knuckles,. where do I anchor the steel-to-rubber hose junction?
BTW My '76 Ford shop manual reads "install and tighten bearing adjusting nut to 50 ft/lbs, the back off 90 degrees, then install the lock ring (pin into closest hole), then tighten outer lock ring to 90-100 ft/lbs".
I saw in another post about checking "End play" what is the procedure for doing that?
SteveL
Huge chevy guy
Hawthorne ca
I think mine has a clamp where it goes from hard to soft line on the housing then floats to the caliper. As for the spindle nuts that sounds right. Wiggle the hub around a little before you tighten em to make sure it's all seated right. Dont remember anything about checking endplay. Sometimes you have to pry the axleshaft outward to get the last snap ring on the hub. Stick a screwdriver in at the u-joint to pry it out.
correct adjustment procedure. Play is checked with a dial-indicator, but you can also do it by feel if you know what's what and your hands were recently calibrated!;);D
Correct for the bracket. The caliper soft hose is located different from the drum one, but I seem to remember the bracket already being there? Or did I pull it off of the '76 front end I used and mount that bracket to the Bronco axle? Dang, hard to remember now!
I'm sure there are pics hereabouts, or maybe in one of the shop manuals, so you can see what we're talking about.
paul
WILDHORSES
USA
No bracket on the Ford disc knuckles. It's not needed the hose set up is completely different than the drum brake stuff.
Jim
Do you still have this stock bracket reamer?
Attaches to the bumpstop mount like this:
Because the soft line on a drum brake does not go all the way to the backing plate, the old knuckle bracket is used as a stabilizer for the soft hose.
With the new hose going all the way to the caliper and therefore pivoting with the knuckle, this bracket further inboard is the only stabilizer for the new soft hose.
WILDHORSES
USA
Possible useful parts and links.
First up brackets middle pic shows the 2 styles. These are the inner brackets which bolt to the bump stop mounts as noted by Paul.
https://www.wildhorses4x4.com/produ...Bracket_76-77_Stainless/Bronco_SS_Brake_Lines
This is a conversion hose that can be used so you don't have to change brackets or front hard lines. This works for adding Ford knuckle out disc brakes to a Dana 44 71 1/2-75.
https://www.wildhorses4x4.com/product/76-79_Caliper_Hose_to_3-16_Inverted_Flare/Bronco_Brake_Hoses
Jim
