Sbolt19
I am in the process of replacing bushings, ball joints, coils, tie rods & adding a track bar riser. I am going from a very old set of Rancho 3.5" coils to a Cage set of 5.5" coils. I have the 7* bushings (and a complete 14 pc. front end set). I had new upper & lower ball joints pressed in on both sides and am going to be going with TRO using the Stone Crusher setup.
With that in mind, what am I going to need to do for wheel alignment? How do I go about finding the correct caster & such? This is something that I have never done before because this is the first time I have ever had to change ball joints. Educate me on this one please.
The second part of my question, you guys running the 5.5" coils, what length shock are you running? Are you using the original shock mounts or have you changed them out? What are opinions for length using stock mounts.
Thanks guys ~ Gary
Thanks guys ~ Gary
