- Nov 3, 2003
- 51,616
Generally speaking tires as old as yours will start to handle noticeably worse as time goes by. Literally nothing to do with visible tread wear, just old age and wearing out internally.Paul, I've read a couple of your posts on various thread about wearing out tires due to age versus tread wearing out - could you comment a bit more on what the observable issues if the inside of the tire is worn out? i.e. is the result of old age is that the sidewalls get weak, and that then translates into tire flex which then results in squirreling driving most noticeable at higher speeds on the freeway.
I’ve never personally experienced it causing a tire to wear unevenly, but that doesn’t mean it can’t be a possible contributor.
Wearing out on the inside (is it a front tire or rear?) usually means something with alignment.
I hear you on the cost of new tires! Very soon I’m going to need three new sets!It's not something I've heard about before on tires and googling around a bit couldn't find anything.
(I'm working through dialing in the freeway driving habits on my rig like the OP, doing the chalk wearing stuff, pressures, etc). My tires are from 2004, but have virtually perfect tread so not super excited about spending 2k on tires unless I can convince myself it's it.
I suppose it’s lucky that my sister-in-law wrecked my Buick otherwise it would be for tires. Thank goodness for small favors.
Very small! :-(
In my experience though, I would never run a tire that old even on a bronco.
Even with less precise handling of a bronco over say a modern truck or a passenger car, you should still be able to feel the difference between 18 year old tires and brand new ones.
