Here goes, and I hope everyone can follow what I'm trying to say.
1975 Bronco Ranger
Could the selector switch go bad and not allow fuel through it? Reason being is that I replace my mechanical Fuel Pump cause I thought that was the issue with nothing getting fuel to the filter and then to the carb. I ended up looking at the selector switch and the hoses to them and they were dry rotten and split, so I replaced those line and still nothing. I even kept the engine running by steadily pouring fuel in the carb to see if it would eventually prime up and nothing. I have a about 8 gallons of fuel in the main tank and about 2 gallons in the aux tank. When I take the line from the main tank that goes into the selector switch gas pours out. Not sure if it's just gravity or what, but nothing is coming through the switch cause it's dry when I remove that section of lines.
Can I just bypass the switch for now and connect the line that goes from the main tank to switch, can I just connect that directly to the line going to the mechanical pump and up to the carb?
Also, is there an actual return line or are those just vent lines that go to the canister, because I see that those lines are corroded and open.
I plan on doing away with the aux tank and upgrading to a new tank in the back, but for now I just trying to get it going.
And by switch, I am meaning the Valve Switch under the seat.
1975 Bronco Ranger
