- Jul 31, 2001
- 8,885
Hope I don't bore ya with this....
Bought my '68 in '76 for $2,000 with 49,800 miles on it.
--289, stock 2 bbl. G78x15" tires-then L70x15" tires. LONG trips with mileage checked on road marker posts every 100 miles so mileage was accurate AND written in a notebook in glove box for 25 yrs...
Installed headers, dual exhaust, s m a l l Carter 4 bbl.... mileage stayed the same but a ton more rpm's available to use and much more power.
This netted 18 mpg consistently at 65-70 mph...when speed limit was lowered to 55mph in WA State back in the oil embargo days we consistently got 19-20mph. This is accurate mileage, filled to the top, and odometer right on and written down on the notepad. Wind resistance I found out is the key to mileage... (lifts really hurt mpg).
My Dad's '69 with a 302 that he ordered from the factory, same tires, eventually we put headers, 4 bbl, same setup he could NEVER got over 14.5... he put 286,000 miles on it and kept accurate records...289 is a MUCH thriftier engine.
Back to my '68...
-- when I put 31's on it I lost on average about 1 mpg
-- when I put 33 x9.50's on it and bumped the gear ratio to 4.10's it stayed the same
-- when I lifted 3 1/2" to put 33 x 11.50's under it I dropped down to 14mpg
Put in a 351W slightly built w/cam, headers, 4bbl
I tried 3 spd trannies with OD, I tried several things to get the mileage back above 16-17 and never could...combination of 2" body lift, 3 1/2" suspension lift affected aerodynamics and mpg.
All tires were BFG except for first set of G78 stockers...
--I ran 35's with 4.10's with ZF/203 combo for 12 yrs and consistently got 14.5mpg at 65mpg with my Q'jet. On a "Manly Man" trip with 8 other Broncos we drove our rigs from Seattle to the Rubicon and back, I got the best mileage of all rigs every time with filled up.
2 of them were fuel injected low mileage Exploder motors, 2 converted EFI 5.0 Mustangs, one of these was brand new. My tire height/tire brand, Q-jet setup beat them all.
I got over 14 mpg on the entire trip, including the best mileage on the trail itself. We wrote the mileage, gal purchased and compared mpg at every fill-up and I wrote them all on my dash... (Eric is my witness)!!! : )
I've always tweaked the odometer gears so it would read accurately.
Stroker
--I was running a very healthy 418 first with my trusted Q-jet for 4 yrs and now with SEFI and EDIS on 37's and 4.56 gears on 37x14.5" wide TOYO's for a couple years and lost 2 mpg!!!!
SOLD THE TOYO's... went to GoodYear MTR's and mileage went back up 2 mpg...those TOYO's just don't roll..in fact, on their website they mention that they have high rolling resistance.
--If I run at 55mph I get 14 mpg on long cruises (200+ miles over mountain passes) with the stroker as I have some country roads we cruise on with those speed limits. Freeway speeds knock me down to 12.5 ... both with the Q-jet and the SEFI...no difference at all.
I'm bumping to 40 MTR's, 5.13, D60 front and lowering suspension/body height ...will see...
There's tons more details on things like swapping to different carbs, I went to Holley ProJection in about '92, etc, etc but too much... : )
Back to my '68...
Stroker
