For speed correction, you can also pace someone with a known good speedometer, or use a GPS application on your phone, or even a GPS device if you have one.
This way you can go at normal traffic speeds and get an accurate reading without trying to calculate all the stuff from 60mph.
But too, there's really no need for all the fear. I know how CA freeways are, and since the legal minimum speed in the right lane only is still 55mph, and that's the legal max for trucks and trailers anyway (yeah, I know... as if they were observing that!) you're not likely in danger of being run over at 60.
There are times when traveling that speed is fine. Just don't check your speedo at commute time!;D At that point it's all just "get out of my way dopey!"
Of course, nowadays "commute time" is relative anyway. About 3:38AM to 3:52AM is your only window of opportunity. So no problem, right?%)
For gear calculation without opening up the diffs, roll either the vehicle or a tire 1 rotation and see how many times the driveshaft turns. This is a relative thing, so there are multiple ways of doing it.
If you don't want to roll the whole truck while someone watches the shaft, jack it up and turn one or two tires. Lockers, limited-slips and open diffs can all act differently. If you jack both tires up and one turns the opposite direction from the other (open diff) the you need to double the number of turns of your driveshaft to calculate the number.
If you leave one tire on the ground, this discrepancy can be eliminated, but if you have a limited-slip or locker it can be very difficult to turn that one tire.
Basically though, if you get roughly 3 and a half turns of the shaft to one turn of the tire, you have 3.50s and if you get just over 4 turns, you likely have 4.11's. If you get more like 4 and a half turns, you could have 4.56 gears.
See? Simple, right?%);D
