Nightstick
Bronco guy
- Feb 6, 2010
- 2,929
No spark, wtf!
Red to + side of coil, black to neg side of coil. You may or may not need the ballast resistor depending on what you bought.
Not doubting you Paul. Have the plain old points replacement module on my son's Mustang with a stock coil and it works fine.
However, if I went to their coil, I would need to supply the full 12v. Just the way I understand it. And I've been wrong before.
No problem. I'm not doubting either, that they can sometimes work on less than 12 volts too, but from experience (and many conversations with different Pertronix personnel) they can be iffy when set up that way. They prefer the higher voltage, as fastcarkenny's experiences seem to bear out as well. Same for the gap, as mentioned. They tend to run more reliably then, and are supposed to be wired that way according to their instructions.
The gap sensitivity may be in relation to just how worn out the distributor shaft/bearings are, but that's just a guess.
Pretty much. Unfortunately, here again they might mess you up by selling coils for both low and high input primary voltages. So you need to pick your part numbers carefully when ordering a coil.
You can buy a Flamethrower to work with a resistor, and another one to work without. And to add to that, they sell identical looking canister coils that are oil-filled (like normal) or fully epoxy-filled instead, for superior heat and vibration resistance.
Those last are intended mainly for racing and air-cooled engine applications (according to them), but in my mind, that makes them perfect for a Bronco and the ones I've used in the past when I had a choice. If they've got a downside, I'm not aware of it.
