Help with cam choice
MonsterBIlly
I know this is for a mustang but its a ford small block either way,
I have a 331 with a t5 and 3.73 gears. I lost oil pressure and it ate a cam bearing. I have the engine blown apart and am trying to decide on a new cam choice. I had a Ford motorsports x303 cam. It ran really good. It dynoed at 399 hp and 415 torque. I think because i have restricting heads. I have the trickflow 175cc fast as cast heads.
Should I stick with the same cam, or is there a better choice to increase the hp a little even if it costs some Tq.
I have the MSD atomic EFI as well and it was tuned really well.
tthis is the x303 cam specs https://www.summitracing.com/parts/cmb-09-0022/make/ford
73azbronco
Your 303 already blew past what would I would have expected. You want more HP, really? I think unless you are trying to do snow romping as your only goal, or 1/4 mile runs, I'd want to up the torque, that is what gets you going, not HP. But again, your numbers are topping out what I think is achievable with a 302/331 based motor.
Sounds like with your well tuned msd atomic setup, you might want to stick to the x303 (even though I would not use ford alphabet cams in a bronco). Going with a new cam, means needing a new tune.
Timmy390
Conway, AR
You didn't say how you use your Bronco. That cam makes power from 2200-6200rpm. I'm guessing like all the 303 series it makes most of its HP and torque up high. If you live up high then good. If you done then the numbers while impressive aren't needed.
Personally I like low end torque to get my 33's rolling off the line.
Tim
The B303 supposedly wasn’t as bad as the E303, but as said they were not perfect for broncos. Especially with many EFI setups. However Billy said this was in a Mustang anyway I think. So that changes the angle on this discussion!
Have forgotten where the X cam falls in that range though.
But you might still ask on the relative compatibility with your EFI setup and see if that opens up other options.
