I've been posting a lot about my recent maintenance project and the issues that keep popping up. This time, I'm having an issue with acceleration. Here is a video of said acceleration (or lack there of): https://youtu.be/AblwqfL1q7A
As you can see in the video, the RPMs do not exceed 2000 RPM and around the 20-second mark the truck bucks.
Background: I recently replaced the intake manifold gaskets, which required removing and reinstalling lots of engine and ignition components. Dumb-ass me didn't mark the distributor where it was prior to removing it so I had to find top dead center using the manual pencil method (i.e. turn the engine over with a wrench and stop when a pencil sticks out the farthest from the #1 shock hole/cylinder.
In regards to other big changes, I replaced the old fuel filter with a new Edelbrock 8134 fuel filter.
I also added brand-new spark plugs and spark wires.
I also added a copper collector gasket between the headers and exhaust.
I have also flushed and swapped out coolant and hoses and recently changed my oil and used Lucas Oil Stabilizer.
I thought the acceleration issue was an air/fuel mixture problem so I attached my vacuum pressure gauge to the carb and made changes but I couldn't get the gauge past 15 Hgs.
I haven't been driving the truck much so I don't know if/when the acceleration issue started or the cause of it.
As always, thank you very much for your help with this issue.
