Hesitant Acceleration
For now we're "assuming" you have a Dura Spark (we have not seen a picture of the distributor yet, so it's still just an assumption) because that's indeed what that module on the wheel well is, you can check the condition of the trigger mechanism inside the distributor with a simple ohm-meter test.
If your distributor has the large round 3-wire plug (Orange, Purple and Black wires) you can separate the connectors and measure between the Orange and Purple wires on the distributor side. The measurement should fall between 400 and 800 ohms. Anywhere near, or outside the limits of that range is bad and the stator needs to be replaced.
Kits are usually available at most parts stores for a few bucks. Well, probably more like $20 bucks these days I'm sure, but it's cheaper than buying a whole new distributor if it's not needed.
But that's why you check the other aspects of a distributor while you're in there. If yours has other issues, then it's time to replace the whole unit.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Re: Timing Light - It looks like the #1 spark is firing at about 22 degrees, which is probably WAY more advanced than it should be for the initial timing. What do you recommend on doing given this info?
I've also included a photo of the engine bay per everyone's' request.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I have a Motorcraft distributor. I tested the orange and purple connectors and the reading came out to .671. I hope that helps.
gr8scott
Are there etched timing marks on the damper and the blue paint is there to highlight them? Most dampers are etched 0, 10, 20, 30 etc. If that's the case
with yours, then it looks to be running at ~12°, which is good. Now post up a picture of the accelerator linkage at the carb and firewall.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I can't sit still so I rechecked TDC and the timing numbers on the harmonic balancer (see images). The initial timing is now set at 10 degrees and the distributor is lined up to the #1 spark wire/post.
Note: The gold mark is 0 degrees and the blue marks are 10-degree increments.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
How are these photos?
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
EDITED -
When I first did my timing reading, I had the distributor connected to the timed vacuum. The initial timing was set around 22-degrees.
After resetting the distributor and TDC to 10-degrees, I disconnected the timed vacuum to the distributor, which is when I got a timing reading of 0-degrees, 10-degrees retarded from when I set TDC.
I have the idle rpm set to ~600.
Newbie question: Is it best practice to set the initial timing with the timed vacuum line disconnected from the distributor?
gr8scott
Cool. Couldn't see the gold mark in the first photo, figured the the first blue line was 0. With the engine idling try working the accelerator at the carb
by hand. Does it rev up good? If so, turn the engine off and have someone step on the pedal to the floor and see how far the accelerator linkage at
the carb moves. Could be a simple adjustment is needed.
B RON CO
Statesville, NC
Hi, you set base timing with the engine warmed up, at idle, with the vacuum hose removed from the distributor, and plugged. I have a handful of golf tees for that.
10* advanced should be good, as long as there is no pinging (detonation).
You can try a little more advance later, as long as there is never any pinging.
It looks like the vacuum port on the left side of the carb is open. This is full manifold vacuum and should not be open.
I don't see throttle return springs.
Take the air cleaner off and have a helper floor the gas pedal (engine off) and make sure the throttle plates fully open.
Good luck
gr8scott
Newbie question: I've been using the timing light with the vacuum line plugged into the distributor and have noticed that many posts/instructions recommend plugging the line when first setting the initial timing. I did this and noticed that the timing was 10-degrees retarded since the last time I checked the timing with the gun.
Is it best practice to set the initial timing with the vacuum line disconnected from the distributor?
Doesn't need to be in your case since you have it plugged into the "timed" vacuum port which doesn't get any vacuum at idle.
Unless your idle is set really high. Have a tachometer? What's your idle RPM's? ~650 is good when running an auto transmission.
As far as i know, the vacuum advance can't retard the timing, only advance it.
oldiron
Are you using ported vacuum or full manifold vacuum to the dist? Check out "thunderhead 289" on youtube. He has a great video explaining the difference on each one.
Greg
gr8scott
looks like he has a blue(?) vacuum cap on the full manifold port, and there is a return spring. He's using the timed/ported vacuum.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I just realized that my post contradicts itself. Let me rephrase:
Slowleak
Georgia
You may have your carb running too rich with the throttle plate slightly open at idle. That would advance the timing when the hose is connected. You should not see a difference in timing at idle if you remove and plug the hose....
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Greg
I have the timed vacuum port connected to the distributor; this is how it was set up when I had the Bronco up-to-code for inspection and the carb installed. The manifold vacuum has been plugged since day-one.
gr8scott
So it advanced your timing 10° from the timed port. That shouldn't happen, as Slowleak mentioned. Assuming you re-set it to 10° w/o the vacuum advance.
When you plugged it back in, did it bump your timing up to 20°? Your throttle plate should be fully closed at 600 rpm idle.
B RON CO
Statesville, NC
Hi, why don't you try this: remove and plug the vacuum hose.
Remove the whole air cleaner assembly. If the air filter is clogged or restrictive it could richen up the mixture.
Set the timing to 10* advance.
Shut the engine and count how many turns in it takes to gently bottom out the idle mixture screws.
Set the idle mixture screws according to the Edelbrock book. Set the idle.
While the air cleaner is off make sure the throttle is fully open when the pedal is pressed.
You can't properly adjust the carb until the ignition is set.
Good luck
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Quick update: I had a moment to start the truck up with the timed vacuum connected to the distributor and the results were the same. For those who forgot:
I set the truck at 10* and removed the vacuum tube from the distributor and the reading was at 0* (i.e. 10-degrees retarded).
I hope to work on the truck a little more tomorrow. Thank you for all of your help thus far.
Then as they were saying, if it is indeed the "timed" or "ported" vacuum fitting, then the throttle blades are open too far and uncovering the transfer port inside the carb.
When the carburetor is idling properly and the throttle blades are almost fully closed, there is ZERO vacuum at the timed port. The fact that you have a change in timing when you connect and disconnect the hose points to a problem with the carburetor's throttle setting.
This can come from either the idle speed screw turned too far in, something physically messing with the linkage, or vacuum leak(s) forcing you to adjust the carburetor wrong.
Messing with the linkage can be the choke's high-idle cam not releasing, or the throttle pedal linkage not letting the throttle retract fully.
For testing purposes, you can leave the vacuum tube disconnected and plugged. You don't need vacuum advance to run. You just need it to take full advantage of things in a street driven vehicle.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
First things first, I want to thank everyone for their help and input with this issue.
Finally some good news! I adjusted the timing on the truck by hooking up my vacuum gauge and turning the distributor. I then adjusted the air/fuel mixture on the carb and the truck is running very well. If anything, it is the quietest I've ever heard it. I am sure the timing needs to be further adjusted but I'm very happy with the results thus far.
Here is the after video I recorded this morning: https://youtu.be/6Xkyvtj_YGE.
