Hydraulic lifter recommendation
nrramse
Who makes a quality hydraulic lifter these days? This is for a stock 302 valve train.
bronco italiano
Oregon camshafts
https://www.oregoncamshaft.com/
Cam research
https://www.camresearchcorp.com/cam-king-camshaft-break-in/
Todays flat tappet and even some popular roller lifter companies are hit and miss.
Nothing is inexpensive anymore, even quality tappets.
My buddy did replace his tappets 2 years ago with edelbrocks and so far so good though.
Depends on what you have done to your motor as the risk you are willing to take if a failure occurs.
Follow the break in procedure exactly as recommended.
ngsd
I just destroyed a new engine witha wiped cam and lifters. I wish I would have spent the moeny for a roller set up. Everything I read after the fact was about how the new chinese made ones are not great metal and this is a regular problem.
SteveL
Huge chevy guy
Hawthorne ca
Don't know how true it is but a couple years ago I I was looking for better lifters to go in with a cam swap. I was talking to a tech guy at summit and he said most lifters come from the same place and get rebadged anymore.
nvrstuk
PNW
From building Ford strokers for a few decades and the last 5 yrs having lifter/cam issues since ALL builds have roller cams, I will not use anything but Howard or Johnson, that said the last one I put together I tried USA made Isky. No issues so far.
I would not use ANY lifter unless it's Johnson, Howard or so far Isky.
Ford Performance lifters were decent. Last 8 yrs are crap. NO Ford Perf, No Summit, no Comp products.
High quality lifters are $1,000/set. Yeah, what happened right??? :(
Lifter failure is the #2 most expensive repair for internal combustion engines.
These are my experiences and I won't spec or assemble an engine w/o roller lifter/cam.
bronco italiano
-More likely than not true for most lifters about same price range. The premium quality are usually made in house such as Oregon cams, Johnson Lifters, Howards.
-I apologize as further research is stating Gaterman lifters are from China and assembled in USA, no bueno.
N
nrramse
I guess I'm off the hook for replacing lifters or replacing the motor (which I was leaning towards, after reading the comments here). I flushed the engine with this stuff and it sounds normal again!
Thanks everyone for the feedback!
So what was wrong in the first place? You just had a light ticking? More than one lifter maybe?
Or some other weird noise going on?
