- Joined
- Jan 24, 2009
- Messages
- 2,552
I am trying to get my hydroboost and 4x4x2 box to bleed but now when I just barely touch the steering wheel it takes on a mind of its own and the whole Bronco starts to shake violently. and the steering wheel would have broke my arm had I not let go of it. After studying the diagram I am sure I have routed the lines correctly.The main pressure line out of the pump went to the passanger side of the hydroboost then from the hydroboost to the 4x4x2 box. I have a dual return Saginaw pump so the return from the hydroboost went back to the pump. and the return from the steering box went to the cooler then back to the pump. does this routing sound correct?
I put the Bronco up on stands and locked the steering all the way to the left with the engine running. then started turning to the right and the steering wheel jumped out of hand so I shut the Bronco down. any suggestions on what I have done wrong?
