- Jun 4, 2002
- 37,110
Hydrostatic drive.
After watching some equipment running around with hydrostatic drives. Everything from streetsweepers, combines, crop sprayers, etc. I had an idea. I also see a flaw in the idea, but I will spoil it later.
So take a standard NP435/D20 combo. Both have PTO options. Put the pump from a hydrostatic drive on the transmission. Put the motor on the transfer case. What does this get you? Well, normally you have a nice NP435/D20 combo to drive around with. When things get interesting, transmission in nuetral and both PTOs go in.
Engine drives pump through transmission.
Motor (hydrostat output) drives into the PTO, which drives the input to the transfer case. Transfer case in low range, get your multiplication. No you can drive infinatly slow, actually stop and change direction without ever really stopping or loosing connection between drivetrail and the ground.
Big, expensive, power limited are all potential problems. But I don't see it as a way to drive all day. Just those real challengine spots.
But I suspect the PTO would not accept the power required to drive. That could get ugly. Then I thought some more, Doubler transfer cases. Cold duck would be nice. What you would want was the first case to be an all gear like the D20, D300, NP205. Not a design with a seperate reduction box such as the Toyota or NP203. None of the chain drive stuff I know of would work either. What you would want to do is put the hydrostatic drive on the front yoke of the transfer case. With the front axle engaged in high it will back feed power into the input of the crawler transfer case at transmission output speed. Then with output in low range, you get reduction. Use the crawler box to then drive the real transfer case (more reduction). You would need the crawler box to have the opposite side drop of what your front axle is.
The bad part is the only way I know this could be done is with an old Cold Duck kit. Just don't cut the front off the crawler box. I don't know of any crawler box conversions that use a NP205 or D300 as the center transfer case. I always thing of the seperate reduction box transfer cases as the donor.
I will admit I have done no real engineering on this. I have not looked up and of the power capacitys, torque requirements, speed limitations, etc. Packaging thoughts have gone as far as put the drive on the opposite side as the front driveshaft, no other thoughts. I don't work around enough hydralics to really know how well this might work. I was impressed with the parking lot sweeper that ran a fixed engine speed and the rocker foot pedal varied speed and direction to what ever the operator wanted.
I am sure someone has tried something like this before on some kind of crawler. I am sure that there are issues I am completely overlooking. But thought I would throw out the thought and see what comes back.
