IAB has a constant loud hiss, idle does not change when I unplug the harness from it.
rjrobin2002
rjrobin2002
Found my problem when I pulled my intake hose off. This adapter had sucked into the throttle body and was partially covering the IAB making the sucking noise. I have not driven it yet.
rjrobin2002
rjrobin2002
I can't believe nobody guessed I had a baseball sized piece of rubber stuck in the throttle body fixing to be sucked into my engine.
rjrobin2002
rjrobin2002
Advanced Auto Part store hose. I mounted the Explorer factory air box where the original Bronco battery was and used this generic hose to connect the throttle body to the MAF on the explorer air box. I did not check to see if this adapter was stuffed inside.
