IAB Orientation???
broncoitis
Anybody have any idea what correct orientation of the IAB should be? I think mine is possibly backwards in order to work with the throttle setup? %)
Viperwolf1
electron whisperer
That is a mustang type IAB and it is oriented correctly. The motor can be clocked to give you more room at the connector but the whole thing shouldn't be flipped so the connector is up.
ransil
Or get a straight connector IAB, something like an 88 F150 if I remember right.
There are 3 different styles of IAB. I'll have to look around for the specs after I get home. And they are orientation specific.
00gyrhed
WHY not up?
I had to turn mine up to clear the casting onmy aftermarket intake. I was in a hurry and didnt have the time to take it bak off and clean it upo, and didnt want to just cut it with a die grinder.
It seems to work just fine, is there a reason not to turn it up with the connector on top?
broncoitis
broncoitis
Well, the whole reason for the question in the first place is that my EFI still idles a bit high. I haven't taken it into a good garage to see if there is something that I have overlooked as of yet but that is coming probably this coming week.
In another thread, Viper said that if it isn't orientated correctly it could affect the way that the engine runs. I guess that was my big concern. Aside from that is there any way to clean the IAB? Carb cleaner i have heard???
Viperwolf1
electron whisperer
Carb cleaner or brake cleaner both work well. How high does it idle? What happens if you disconnect the IAB when it's idling? It should slow down to the point where it barely keeps running. If it still runs fast you either have the throttle stop screw adjusted too far in or you have a vacuum leak.
broncoitis
broncoitis
it idles around 900 - 1000 ish! I will try disconnecting it and see what happens. From what I remember, it stalls I think.
roundhouse
I unplugged mine. It was causing what I call hanging
When you go to shift gears and back off the gas the IAC caused the rpm to drop real slowly
I have it on a switch so I can flip it on for cold starts in the morning Then I cut it off for the rest of the day
EFI Guy
TheEFIguy@gmail
BFE
The reason you want the IAC mounted correctly is because the engine vacuum assists in closing the valve. Flipping it puts engine vacuum on the other port and tries to hold the valve open causing a high idle.
Some people have flipped them with no issues, the last one I tried flipping idled way too high. I suspect the reason that some can be flipped is because they have different styles of return springs inside. I've seen a couple of different style return springs in valves that otherwise look identical.
Ford has 3 styles of IAB. Two different Hitachi and one by Nippindenso.
The Hitachi are metal body. Straight plug is common. There is also an angled plug that also has an external vent. That vent is nothing special, vents an internal cavity. Both of these are designed to take air in the coil side of the IAB and vacuum side is far away from the plug.
The Hippindenso version is black plastic body. Square shaped, not round body like the Hitachi. This flows backwards. Air comes in far from the plug and vacuum is nearest the coil. I have one of these on the '95 mustang engine in the garage.
broncoitis
broncoitis
I think I am gonna just take this over to a guy I know that seems to be a pretty good mechanic. The stuff that he has to diagnose problems vs what I have is night and day. Probably take him a day to solve what would take me forever.
On another note, I don't know if this is true or not but according to him there is a big difference in the quality of the OEM sensors from Ford,Dodge,Chevy,etc.... vs what you get from Autozone and the other retail stores. I think that there is alot of truth to this potentially. :eek:
u10072
If no one else will say it-- very nice execution on the engine bay! Definitely how its supposed to be done! Kuddos!
bax
Old Member
I was thinking the same thing. Very nice.
landshark99
Montrose, Colorado
I had some issues with high idle on mine suspected the iab however it was the tps. I had to follow the directions to set the voltage and make sure the sensor was on the correct side of the throttle knob.
If you haven't already maybe set the voltage.
00gyrhed
Did the adapter between the HB and the MC that allows the HB to be clocked 90° have to be fanned or does someone sell it?
broncoitis
broncoitis
I am not sure what you mean by setting the voltage on the TPS! I know that my sensor is from Auto Zone so that could be problem number one. I also know that I have it clocked all the way to the lowest setting I think. Not sure what you mean by the correct side of the throttle knob.
I got my Hydroboost setup from WildHorses. Everything included and bolt it in. Cannot complain at all. Seems to work and work very well. Hopefully that is what you are referring to with HB and MC!
