Junkyard Shopping!
Bator
Las Vegas
Hey ya'll
Tomorrow I heading to the junkyard to search for front disk brakes for the all ford conversion. I just wanted to know if there were any special tools that I need to bring with me to get everything from the knuckles out off a 78 -79 bronco. I called the yard today and they have 5 or 6 to choose from and a bunch of F150 4x4. Anything I need to watch out for?? Thanx
eBronc
Austin, Texas
Don't forget the band-aids..
Bator said:
Hey ya'll
To loosen the rust:
A gallon or two of Liquid Wrench (or PB Blaster)
Propane torch
To remove the ball joint nuts:
3 or 4 foot long breaker bar
Impact socket set
Lineman's pliers to cut the old rubber brake hose
BFH
Tie rod end and/or ball joint pickle fork
Things to watch out for:
Snakes
Ants
Wasps (hornets, bees, whatever)
brian72
Early Bronco Student
you will need a dana 44 hub socket (picture http://www.bcbroncos.com/hubsocket1.gif) and a ball joint socket (picture http://www.bcbroncos.com/balljointsocket1.gif). These sure do make the job easier. Make sure you take a couple small diameter flat blade 6" inch long screwdrivers. Take some GoJo hand cleaner with you..you will get greasy. 5 pound sledge.
Get the tie rod and draglink...you could do a TRO
also get any 4x4 steering gear boxes.
Bator
Bator
Las Vegas
Thanx for the replys you guys! I don't think I naad to worry about bees and stuff this time of year but thanx anyway. I knew about needed the one socket but not the other. Much thanx Brian72!
