So now that it's back from dyno I wanted to sort out my internal clutch slave situation.
I originally bought a Wilwood external slave that would pull, so I was gonna make a little bracket off the tcase or trans, and drill a hole in the clutch fork to have it pull it back.
This brought a few issues of packaging and whatnot- nothing that couldn't be overcome- but Wilwood made the body of the unit move with the hydraulic hose- which I thought wasn't the smartest thing in the world. Now, you have a clutch hose thats moving every time you pushed in the clutch.
So, time to build a better mousetrap.
McLeod was the answer.
This is a Luk Clutch pressure plate, and an 11" clutch disc to go on the nv3550 from Tom's Bronco parts.
I'm hoping this clutch will hold up to the power now.
Initially I tried doing this with a tape measure, but it was ineffective at producing accurate enough results.
Yes, I know there isn't a clutch disc in these photos.
YOU HAVE TO HAVE THE CLUTCH DISC INSTALLED DURING MEASUREMENT!
I measured the input shaft of the NV3550 and went on
https://www.mcleodracing.com/ to go find something that may work.
So I ordered one up
Here's the part number 1400-30
and the link
https://www.summitracing.com/parts/mcl-1400-30
Whats in the BOX?!
This is whats in the box
She's a beut, Clark!
So, what's neat about this is how it's adjusted. this ring here can spin to adjust it's depth.
I used some of this to lubricate the orings. Big fan of this for oring lube in general.
ploop
slid right one (after I scuffed the nose of the transmission and cleaned it)
So the object of the game is to get the TOB to be close to the PP. so you have to do some measuring
Again, using a tape measure was NOT accurate enough, I used a pair of calipers to do this, but holding calipers sucks trying to take a pic, so tape measure it is for you
In my case, I had to use the ring that is supplied to space it away from the transmission.
Messing with the ring, threading it out and the ring got me to within .100 of what I needed.
So, A combo of flat measuring stick devices, along with careful tongue holding eventually got me an average between one side and the other from the block to the face of the pressure plate.
Without the bellhousing on it.
With the bellhousing on it, the hoses tight, and ziptied to keep it from moving around
Thru a new clutch fork boot.
I had to spin it "out" (closer to trans) to get the throw out bearing to spin with my finger, so i unbolted the trans, moved it back enough to push the hoses back in, and spun the whole thing one revolution inside the bellhousing. no biggie.
But, tadaaa!
She's ready to be bled and off we go!
Engine/trans/tcase are back in.
Waiting on Jess from Hi Angle to get me the rear output flange, and Wildhorses for a 32 spline output.
I should've done that before, but honestly didn't know the Dana 20 weakness, nor knew the actual power the engine was going to make.
