So circle back to the heavy duty motor mounts that didn't want to fit.
Tom's bronco parts sent me another set- and they fit marginally better, but still didnt fit worth a shit.
so, I milled slots in them to move them where they needed to be in the first place.
Stock motor mounts: slam dunk.
HD motor mounts: dont fit.
me thinks its the manufacturing of those mounts.
so, they are in and I had to get that done before my little exhaust escapade.
So here's my little system I came up with to hang the exhaust.
I didn't want to use the shitty straps, and wasn't keen on trying to make bar work and mount onto the frame.
This is a linear actuator bracket, with a Summit racing silicone exhaust grommet, and had my buddy make me some stainless stand offs on the waterjet (if anyone wants something similar, just le me know and I'll put you in touch with him)
I tried using Stainlessworks brackets, but they only come in too short, or too long for my little idea.
So, I also got some aluminum spacers to go inside the grommet to make the pin the linear actuator work.
Pretty painless once I figured out which parts worked with what.
Then I sorted out where the O2 sensors were gonna go
then hacked off the collector flange and welded a Vband on it to hold the flex section
Yeesh. This took longer than expected.
The mufflers are all TIG'd up, now to make the headers to mufflers part.
Hopefully I can use the SW brackets I now have for the tail pipes.
Unsure if I'll be able to do those until the body is on the truck, as I don't know where the rear quarter panel lands vs the frame.
Would suck to make rear tail pipes and it hit the body, or hang down low!
