LORE Bronco restore
sprdv1
REBEL
LOL, a great feeling I'm sure.. Loving the work space you have
so, this was a big mental milestone for me. I'm not sure why, but it just was lol
Not that anything is final torqued, done, complete or anything- but the fkin axles are back in :)
halogrinder
halogrinder
Houston
Things got complicated today.
First off. Little background on myself.
I've mounted/dismounted thousands of tires, no lie. Not exaggerating. Thousands.
These 15" 15 year old Maxxis buckhorns straight whooped my ass.
My 1 year old 30k @hunterengineering #auto34 couldn't get them off conventional style or reverse drop flipped.
Whooped. My. Ass.
I ended up using a sawzall to cut the beads to get them off. It was heavy suck-o-rama.
I can take a 315/35/20 runflat and this machine will effortlessly remove that rubber band from a BMW wheel, no prob.
But some 15" tires?
I ate some humble pie today, it's crunchy and tastes good with ketchup.
So anyways- I have a problem and need your help.
Notice the differences in these wheels. My pops never realized
1. One of the 4 wheels on the ground has a different center bore than the other 3. It's like the 8.5" 1" pos offset US Indy Mag that is for the spare- they have matching bores, but are different width and backspace.
2. That wheel is a different make than the other 3. They also have no casting markings to identify who made them.
3. It also has a different backspace by about 3/8" then the other 3.
4. Of the 3 that have the same ribs on the back, one is machined different. Sharp edge vs radius edge on the back, and the casting divots are machined off of it at the wheel mounting surface. 🤔
5. Complicating this more, the holes vs where they are drilled to the slots are different, too
So. I need to find a wheel that matches the other 3 (15", 10" wide with the correct back space of 3 1/4" (rear rim flange to wheel mounting surface)
Anyone have any leads?
Check out the goofy drop on the wheel, too. The drop center is like...well...in the middle and that makes it a heavy game of no fun dismounting.
20201130_120122-jpg.3112122
20201130_121244-jpg.3112123
20201130_121815-jpg.3112124
20201130_121848-jpg.3112125
img_20201130_213510_031-jpg.3112127
20201130_115124-jpg.3112121
House
Minutia Militia
Sorry I didn’t have a match for you...
Interested in that US Indy to complete my set though! :)
sprdv1
REBEL
Weird, that's new to me... someone ought to know...
wonder where ole Franko is hiding, he would
halogrinder
halogrinder
Houston
Where the hell have you been!?
Ok look, it's complicated.
The 'rona, staffing issues, business issues, personal time issues, lots of stuff made it impossible to touch this since what- November?
Sheesh.
So, things are better now, so I'm about to get rolling again on it. Got the hard lines for the axles bent up, double flared all that fun stuff with stainless rock guards on 'em. They came out ok.
20210210_163314-jpg.3114646
20210210_163337-jpg.3114648
20210210_163328-jpg.3114647
20210210_163301-jpg.3114645
Been messing with the brake lines and layout. Finally decided to throw the drivetrain into the frame so I could visualize this better.
See these extreme mounts?
They suck.
Why? Because they are built incorrect.
It took the back of the trans and put it into the driver's frame rail.
If you pushed hard enough the bolts would eventually go into the crossmember, but then the engine was tilted severely passenger side high. I FOUGHT THESE THINGS for a solid 2 hours back and forth swapping them and trying to get the drivetrain to sit level.
Finally I gave up and threw some stock motor mounts on.
Guess what. Dropped right in without an issue.
Ugh. If your gonna make something, make it fit!
Anyways, now I can run fuel/brake lines and exhaust while I'm waiting for my intake to get cut.
20210218_170624-jpg.3114649
20210218_170632-jpg.3114651
20210218_170627-jpg.3114650
20210218_173925-jpg.3114652
tasker
all knowing of nothing
NH
AMAZING WORK!! and i can concur on the extreme mounts for me as well....
phred
Earth
I feel ya on those mounts. I installed some on a truck I built a few years ago. Ended up modifying them to work. That’s what the customer wanted and he paid for it but holy heck what a pain
halogrinder
halogrinder
Houston
Been bananas this week recovering from last week's freeze down here in Houston. A few pieces of equipment went down, some pipes burst and other nonsense.
Didn't get to do much other than try to lay out my exhaust/fuel system/brake lines, waiting for more fuel fittings to show up and whatnot.
This is a flex pipe for the header flange that will have a V band welded to it. I weld the ends of the flex pipe up, then knock it flat on a 12" disk. Makes welding them up nice. This was fusion only, no filler and some foot pedal pulsing to get it to close up without blowing out.
flex-pipe-jpg.3114901
halogrinder
halogrinder
Houston
So.... I tacked these together, and I think I'm going to run a "muffler module" of some sort now.
One, they can't lay flat due to inside frame width
Two, it'll make them (I hope!) Easier to handle with them joined together.
Three v-bands makes it leak free and easy to remove if needed.
Now to think up ways of making exhaust mounts ����
1614656783018-png.3114967
halogrinder
halogrinder
Houston
So circle back to the heavy duty motor mounts that didn't want to fit.
Tom's bronco parts sent me another set- and they fit marginally better, but still didnt fit worth a shit.
so, I milled slots in them to move them where they needed to be in the first place.
Stock motor mounts: slam dunk.
HD motor mounts: dont fit.
me thinks its the manufacturing of those mounts.
so, they are in and I had to get that done before my little exhaust escapade.
So here's my little system I came up with to hang the exhaust.
I didn't want to use the shitty straps, and wasn't keen on trying to make bar work and mount onto the frame.
This is a linear actuator bracket, with a Summit racing silicone exhaust grommet, and had my buddy make me some stainless stand offs on the waterjet (if anyone wants something similar, just le me know and I'll put you in touch with him)
I tried using Stainlessworks brackets, but they only come in too short, or too long for my little idea.
So, I also got some aluminum spacers to go inside the grommet to make the pin the linear actuator work.
Pretty painless once I figured out which parts worked with what.
20210312_130831-jpg.3115442
20210312_130901-jpg.3115443
20210312_130905-jpg.3115444
Then I sorted out where the O2 sensors were gonna go
20210312_142933-jpg.3115445
20210312_142941-jpg.3115446
then hacked off the collector flange and welded a Vband on it to hold the flex section
20210312_142958-jpg.3115447
Yeesh. This took longer than expected.
The mufflers are all TIG'd up, now to make the headers to mufflers part.
Hopefully I can use the SW brackets I now have for the tail pipes.
Unsure if I'll be able to do those until the body is on the truck, as I don't know where the rear quarter panel lands vs the frame.
Would suck to make rear tail pipes and it hit the body, or hang down low!
img_20210324_190845_022-jpg.3115448
img_20210324_190844_996-jpg.3115449
img_20210324_190845_054-jpg.3115450
sprdv1
REBEL
Nice fab work bud....
halogrinder
halogrinder
Houston
Productive day
Stupid Dipstick I bought didn't work at all-
so, I made one.
may re- make it with stainless or steel vs the cupronickle tubing I used.
Now to sort out how to fix the bubbles in this roof line on my tow truck....
resized_resized_20210325_160241-1-jpeg.3115467
img_20210325_163946_966-jpg.3115468
img_20210325_163947_031-jpg.3115469
20210325_160323-jpg.3115470
img_20210325_163946_981-jpg.3115465
20210325_171948-jpg.3115472
20210325_164751-jpg.3115474
halogrinder
halogrinder
Houston
Worked on the tow truck a little-
fixed up the roof with some POR15, and re-shooting the top of it to seal it up.
Regasketed/sealed/rubbered all the doors.
img_20210402_101252_080-jpg.3115778
img_20210402_111424_550-jpg.3115779
Made some fuel lines
img_20210405_172055_511-jpg.3115775
20210405_171356-jpg.3115776
20210405_171345-jpg.3115777
fb_img_1617672187489-jpg.3115774
halogrinder
halogrinder
Houston
week ending update-
So I'm hoping to have my intake on Monday.
I cut my valve covers to have the breather and -8 AN fitting for my PCV set up.
got a PCV setup mocked up for dyno use, will re-do with the same catch can/PCV system but with legit hoses and stuff once it's in the truck and I can sort out plumbing.
worked on the farm truck. Roof is getting cleaned up from some pin holes and rust- reshooting it with wimbelton white.
Decided to give er' a good ole rub and wow the results were worth it! lol
I used Dura-Coating Step 1 compound, then 2n1 polish on a foam pad.
Directions says run the compound a few times, wipe off with a microfiber, same similarly to the 2n1-
I didn't follow the instructions, and just got after it. If I cared more, it'd probably come out even better- but I'm happy with the insane results these products did.
I have the metal shine and tire shine, too. its killer stuff.
anyways. It's 100% operational now.
Literally, everything works like it was new. Even the washer pump lol
Just some time now to finish the body work up on the roof, drop in new rubber/windshield, and I'll give it a good water test before pulling the seats to recover and throw down some jute/vinyl for flooring.
Had to do two patches- one on driver side because the windshield leaked and pooled up under the jute.
The other was in the middle of the passenger pan, i think from a second water leak from the windshield and was running down onto the trans doghouse.
Cleaned the doghouse up with my muriatic acid solution I've previously discussed.
20210406_100619-jpg.3115910
20210407_090656-jpg.3115911
20210407_080259-jpg.3115915
20210408_140709-jpg.3115912
img_20210408_181952_699-jpg.3115913
img_20210408_181952_725-jpg.3115914
