LORE Bronco restore
Had to trim about 7/8" off the shroud to get the fan to sit on the inside/against the radiator so it would clear the water pump.
Tight fit even with the Explorer accessory drive!
Seems it's always a part of life for a Bronco builder...
Mapping out exhaust options. Me thinks about here with a 3" tip.
buuuuuut the gas tank strap is sorta directly in my way. Suggestions?
Are you dead set on discrete duals, exiting on both sides? A single is much easier, sounds good but is less cool for sure. And maybe duals is how your dad had it originally?
Or duals out the passenger side only. That's how mine is and I like it a lot. Thinking of single next time, but I like the dual aspect, but the simplicity (and lack of fumes in the enclosed cabin) of running exhaust on the right side of the rig.
Good luck either way!
halogrinder
halogrinder
Houston
this is much easier than a BMW E30 3 series engine swap. the shroud just plain won't fit period with a fan :D
Originally it was headers to a set of cherry bombs and exiting under the doors- We're trying to refine the ole' girl a little bit from that type of setup.
halogrinder
halogrinder
Houston
Working on the wiring :D
20211124_142727-jpg.3120203
20211124_155451-jpg.3120204
20211124_161745-jpg.3120205
halogrinder
halogrinder
Houston
ok.....so where would you mount this PSC reservoir, and secondly- those of you that use this pump setup
20211129_140045-jpg.3120236
20211129_140112-jpg.3120237
20211129_140123-jpg.3120238
- do you think it's going to have a suction/priming issue with the inlet being lower than the pump?
Firewall looks to be the easiest.
Facing towards the back would make plumbing the easiest if its on the engine.
facing towards driver fender looks like I'll have some issues with hose management and fitting to the fender.
Thoughts?
fordfan
It's looking great! It's always a challenge to modify because when you alter one thing, you have to massage a half dozen other things to make it work.
For the exhaust, I have been very pleased with a 3" single pipe on the "Rattler" Bronco. The exhaust is plenty for the Cleveland power with AFD aluminum heads and 2.5" collectors on the headers. I have two 2.5" pipes into a huge single stainless muffler with a 3" single outlet. I love it! It's nice and tame sounding at low RPM with a deep burble sound and as the RPM goes higher, so does the scream...;D;D;D
halogrinder
halogrinder
Houston
sorry- been busy and haven't updated!~
the TBP steering shaft was about 2.5" too long to even think about fitting. so i chopped it down and fixed that situation.
20211203_091626-jpg.3120736
20211210_082708-jpg.3120737
This Molex connector on the Spal fan wasn't what I wanted. Deutsche connectors FTW. Amphenol if you want a cheaper alternative. I will tell you though, its easier to get kit forms from places like prowireusa and other places.... ive got a pile of random locks and pins from my recent wiring adventures trying to piece things together
20211208_144045-jpg.3120738
20211208_152446-jpg.3120739
not crazy about this hose- will come up with a better solution
figured out what to do with my exhaust and tank strap situation- using two holes already in the frame rails.
20211208_165732-jpg.3120741
20211208_165827-jpg.3120742
Open barreled splices with Raychem SCL is the way things are done. This specific one is ignition on to the control side of the relays.
20211215_164045-jpg.3120743
20211215_164050-jpg.3120744
Wiring stuffs.
Everything was done in Raychem DR-25 and SCL. This stuff is the best heat shrink you'll ever use.
Ran out of 3/4 DR-25- waiting for more so I can finish it.
You can use the SCL as poor man boots.
You need a GOOD heat gun to melt the adhesive in the SCL, too.
give it a pinch and it seals the middle of the joint up, and the SCL gets very stiff/hard.
20211208_160329-jpg.3120746
20211208_160337-jpg.3120747
fb_img_1639707504488-jpg.3120748
20211221_144103-jpg.3120749
20211221_150421-jpg.3120750
20211222_175956-jpg.3120751
20211206_180121-jpg.3120752
aaaaand for the first time in forever- power has run through its veins again.....
20211217_162748-jpg.3120753
so, entire truck-
1. i put the hi/lo power wires to the blower switch backwards. Had no idea which one went where :D simple flip.
2. cigar lighter and element is junk, it insta-pops the fuse when you push it in- getting another one.
Other than that, everything worked as I expected it to.
brakes/steering/lines/linkage sorted out for the most part
20211222_175913-jpg.3120754
halogrinder
halogrinder
Houston
Gas tank, tire carrier and everything mocked up..... man its lookin good!
20211222_113814-jpg.3120755
She's alive.
oh, and I also drove around like this for a week back and forth to work- it was VERY entertaining
20211215_175839-jpg.3120756
fb_img_1640226778896-jpg.3120757
side mission is getting the crew cab up and on the new chassis that found it's way on my trailer a few weeks ago, too
20211222_180645-jpg.3120758
halogrinder
halogrinder
Houston
Today was very productive. I got the wiring harness done in the engine bay, almost everything's done on the body harness. Waiting on a few things from powder coat so I'm at a little bit of a stopping point. Hung the fenders and the grill so I can finish the headlights and turn signal wiring, and route the fog lights that I'm hoping to see from @kchilites .... I'm going to have to put a gear reduction starter on it, the starter just can't get the engine to spin over at a speed that will fired off dependably. Waiting on parts for next week.
I think a mid 90's gear reduction starter will work?
20211230_175951-jpg.3120832
20211230_175947-jpg.3120833
20211230_175943-jpg.3120834
sprdv1
REBEL
heck yeah.. I could damn sure use your type of motivation.. Gonna be a sweet ride
halogrinder
halogrinder
Houston
Got the flares installed.
20220106_161401-jpg.3120976
Tach installed.
Dash cap installed.
20220105_174656-jpg.3120977
Figured out how to mount this thing finally.
20220105_161101-jpg.3120978
Illumination looks a little biased in the pic, but isn't as bad in person
20220104_180637-jpg.3120979
These on the other hand, are gonna have to be calmed down lol
these things are bright lol
20220104_175925-jpg.3120980
Duff roll pan lookin sweet!
20220104_174759-jpg.3120981
Front bumper and skid plate installed- gets to come back off because I need to mount the p/s cooler lol fk.
20220104_174740-jpg.3120982
20220104_174719-copy-jpg.3120984
halogrinder
halogrinder
Houston
That's all you had to do, Tom's bronco parts......
All you had to do was just supply a small spacer to take the slack up on the bolt anchors, and it would be miles better than "this is what we supply, we've been doing that for years".
A 7/16 bolt in a .600 hole is not "ok", despite what you say you've been doing for years.
Safety is a priority, don't cop out with that excuse.
So, I made spacers to take the slack up, not have the belt ride directly on threads, and allow the bolt some chance of being centered upon an impact and not rip the head through the hole.
The back seat bolts are exposed-
so I used mustang bolts, cut their shoulder down as well so they wouldn't be so proud in the bed, and made spacers for them as well.
Do it once, do it right.
seatbelt-jpg.3120993
20220107_175905-jpg.3120986
20220107_175859-jpg.3120987
20220107_175456-jpg.3120988
20220107_175435-jpg.3120989
Got tired of staring at the parts house hose wall- so I made on instead.
screenshot_20220107-104020_instagram-jpg.3120990
20220107_095833-jpg.3120991
Made a -10 inlet for my p/s pump
20220106_170250-jpg.3120992
JeffG
San Antonio, TX
The details are looking amazing. I'm not sure I understand what you did to the seatbelts. Mine came from WH, but I'm sure they are the same or similar. I just bolted them in and done. I recall not liking how it pinched the upper mount against the roll bars and it doesn't swivel when you are putting the seat belt on or off
I'm sure it will make more sense when you show them mounted. Any interest in making more spacers or providing measurements? I might be able to find something close from A&A Mfg.
https://www.aa-mfg.com/product-category/nuts-and-spacer-bushings/
halogrinder
halogrinder
Houston
the seatbelt anchor is .600.
7/16 is around .430.
mustang bolts that TBP and other sell are .500.
You DON'T want seatbelts riding on threads.
You DON'T want a bolt loose like that in a hole.
You have a strong chance of ripping the anchor off that bolt head like the way they shipped it in an accident.
904Bronco
San Martin, CA
Completely agree, I have had to do the same thing for 3-point belt rollbar mounts. There is "No" Halfway with Safety equipment.
toddz69
Holy cow - this is coming along nicely! Loving the updates!
Todd Z.
JeffG
San Antonio, TX
I understand now. Thank you for this information. Time to update my seat belt mounts.
