I also have the flotek heads on a 93 roller block stock cobra cam but haven’t ran it yet. Did you check piston to valve clearance? The bigger valves can get close to the pistons. Had to change to bigger valve relief pistons on mine, of course I didn’t know this until I had the whole thing assembled with stock pistons and happened to mention the scenario to my machine shop. Took it apart and clayed the pistons- too close.
Yeah, I started this way before and when I checked I had enough clearance. I was a little paranoid maybe I screwed it up somehow or the engine was open for so long something fell in lol that's why I bought one of those endoscope cameras and snuck it in the cylinders. I had all the ports plugged up so hopefully nothing could fall in but I have had chipmunks get up in there and they don't care.
the original sound was pretty bad though, it sounded like if the valves were being closed by a pushrod and rocker arm instead of just being opened by one, It ran strong while making the sound but it way too loud. Now it sounds like a gas powered sewing machine with a slight exhaust leak
