panalukes
Here is one for the electrons.
I am having issues with my stereo cutting out while the engine is running and I'm stopped in drive. The rpm is 700ish at this point. My volt meter shows it drop to 11.7 volts, this with the engine running. If I put the engine in park the rpm will climb enough that the voltage climbs and stereo comes back on, Stereo doesn't cut out while the engine is off and it's just running on the battery. I only get the low volts when the engine is running. it's been like this ever since I got the vehicle. I don't have any problems with dead batteries though so I'm puzzled. Could my alternator be putting a load on the battery at low rpm? I have multiple grounds. I haven't had the alternator tested. I believe it's a newer type alternator setup. Pictures to follow. Sumtin ain't right.
