LOWERING my Bronco
behemoth
I have thought about the cage-rollbar but I can not see one that does not break up the lines. If I was to do anything it would probably be chrome and very small. With the height required ( basically the height of the windshield) it would really stand out. As low as mine sits I can not see a roll over unless some extreme failure happens.
Aparently mine sits lower than Dales does as I had to deal with the inner fenders could be the height as well as my moving the front axle forward a bit.
With the width of the front suspension the tires sit far enough in to clear the fenders when turning. I will have to roll mine and I knew this going in.
Looking back I would probably not drop it this far, but were only speaking an inch at most.
The harness I used is the one I took from the mustang and sent it to Kolibar to have it done.
What measurements do you want from my truck, front fender lip to wheel center ?
behemoth
stock, and stock original switch I bought this truck not running so I did not know the condition of the other parts. I was going to swap out the headlight switch as well as the brake light switch as they are originals and easy.
greatguy57078
greatguy57078
The measurements on mine from frame to ground and body to ground are different not constant as I bagged the rear on mine. I can get you the wheel base and the back of the frame to axle center if that is what you need.
I basically pushed the rear axle back as far as I could go so that when the bags are empty and sitting on the bumpstops the diff cover just clears the rear crossmember.
The wheel base measurement should be enough, as the Mustang II IFS does not give alot of "wiggle room" as you had once stated. I have already welded my rear end in, so whether I choose to relocate it again would be just another change of direction. If I am doing the math right, right around 94"-95" (give or take) would center the rear tire in the wheel well.
bronko69er
EB Addict
Renton, WA
So if the rear cross member wasn't in the way or any other limiters, what would be the ideal wheel base to center the wheels in both front and rear fenderwells? 94"-95"? Or 96"?
greatguy57078
greatguy57078
If the measurements are right that Dale shared with me I would say 95 1/4" would put you center of the rear wheel opening.
behemoth
The stock wheel base is 92" mine is 94"
greatguy57078
greatguy57078
Thanks Bill. I do personally think that it looks better like yours back 2-3 inches. To each his own! I would drive either one! ;D
behemoth
I keep looking at these photos and where I like the look of them both, I am glad I moved the rear axle back. Mine now has a maghitech diff cover on it and it just clears the rear crossmember. The plastic clip that holds the original fuel tank wires has to go.
I hopefully will get the window frames off soon to get a look at it without them. No matter what we do I feel due to the lenght and height of these things chopping or slanting the windshield will still have some proportion that looks off. Since I have plans to run the full hard top mine will stay stock. I will pull the soft top riser off of it to help with the height.
Paint shop pro has been a nice tool in looking at the windshield.
broncoman1972
Years back there was a white lifted EB in one of the 4wd mags that had the windshield raked. If I remember correctly I saved the pic somewhere. I will try to find it and scan it if I can.
Great lookig rigs, by the way. I have been keeping a close eye on this thread for some time. My project has fallen by the side for some time and when I restart I am considering this option.
broncoman1972
Damn.. It's kinda scary that I found this, but here you go... One EB with a raked windshield..
Says windshield is not chopped but rather raked back 32 degrees. Oh and the shaved suicide doors are pretty sick too...:cool:
Oh yeah, and it's packing 390 inches....
77bronco_ed
Start of build almost ready to move forward!
Getting ready to move forward on my own street bronco project. I have been building up my stash of parts. I debated on whether I was going to use the 74 Bronco I picked up for the project. I finally decided that I will use it. I am moving forward on another frame so I still have a chance to pick up another body that may not be in as good of shape. Most of everything is craiglist search and purchase.
Parts ready for build.
1974 Bronco
Spare frame
Rear
Wheels 15" Micky Thompson 31x18, Sportsman radials
15" 15" wide Centerline Warrior wheels 5" backspacing
Wildwood Rear disk brake set up.
Ford 9 " (Narrowed may need further modifications)
4 link for rear
panhard bar
Front
Heidts Mustang II parts
spindles,rotors
Tube upper /lower arms
Rack and pinion
Ordering front cross member next week
Having rectangular tubing bent to replace rear section of frame.
Will allow clearance to lower truck, rails will be mounted inboard 3" each side
for fitment of wheels.
Should have enough parts to start moving forward as the weather changes... (Added heater to garage last winter so I should be set to go ;)
I'll have to peruse the thread to see where the areas that need special attention.
Getting excited!
behemoth
I would suggest looking at lowering the front cross member to keep the stink bug look to a minimum. If you look at the pictures of the crossmember placement in this thread it puts the front very low.(nothing wrong with it).
I wanted low and I got it, the issue is the rake rear to front. Without cutting the bed for the c notch you will have about 3" of rake depending upon rear suspension choice. I have 4 link and air bags so I can adjust it but the lower i go in the rear the more offten I will hit the bump stops.
Your going to tub yours so you can take this into consideration. I am being told that I should cut the c notch more. We will see in time.
I am looking forward to seeing all of these come out.
77bronco_ed
will you have to narrow the frame and tub the body for the big 18's?
Yep... each rail (at the rear) will be moved inboard the thickness of the frame. (3")
I will have the rear rails bent up. 2x4 rectangular tubing.. Already priced. Once I have a template, and measurements I'll send it in and they will bend to the template. The stock rails will be cut away. Basically the same only inboard and large channel similar to c notch.
This is going to be tough I never tubbed a vehicle and... I am doing it on a spare frame. Measure, measure, measure... I have been asking questions on the hotrod forums.
-Ed
77bronco_ed
I purchased the Heidts mustang ii components used... mocked up and sitting, he changed his mind on his project direction. He was going to toss the front section of the frame and I picked it up. There is a heidts crossmember. Initially I thought there was not a chance to use it however now that I had a chance to measure things the inside to inside dimension is exactly the same as the Bronco 23" I will cut the caps and member, clean em up and see where I am at. I think the effort of removing could be worth it.
Only problem is I don't have any instructions. I can toss a few parts back on and take some dimensions while together. I'll also contact Heidt's to see if I can get some info from them. Anything you guys have on the cross member in terms of fitment and key dimension or items that you experienced I would appreciate your insight. Like the Stink bug comment. I don't know what that means but it must have something to do with sitting in the weeds. I am not really into the slammed look so your comment is appreciated.
-Ed
77bronco_ed
Thanks,
I will tub but I want to try to keep the bed intact. Adjust the wheels tubs to accomodate the tires. I want to keep the bed looking stock except for the modified stock wheel tubs. The plan is to make them look the same only wider larger where necessary.
I was even thinking about shortening the bench seat having it look the same but... it may only be big enough for a single person ;)
How many inches did you and Marty C notch the frame? 3" ?
I'll have the rails bent to what will fit under the tubs.
-Ed
greatguy57078
greatguy57078
I don't remember exactly what I did. I thought that I had posted all that along the way, but it has been a few months (years?)! I was at the body shop twice this week, and snapped a few pics while I was hanging out. Hopefully they will get this chop finished up in the next couple weeks. Then I can set this baby on the other frame and see what she looks like. Lots and lots of work left, but maybe just maybe....you guys will see me show up for one of the "local" get togethers next summer!:cool:
