Seriously considering doing this upgrade while the engine is out. I think I've read every word about it on CB, just want to ask a few questions to make sure I am ready to pull the trigger on this swap.
1. Alrighty, so can you use the 4x2 tranny, or only the 4x4?
2. ZF adapter for the D20 and she bolts on up?
3. Need to get the slave cylinder with the tranny and use Bronco clutch (302) right?
4. Gotta build your own cross member?
5. Should I get the truck's master cylinder or use an aftermarket, or does it matter?
6. Adapter kit comes with a mount for the t-shift. I understand you can keep it as long as shifter clears, right? Otherwise, twin-stick it.
7. Driveshaft mods required?
