chuzie
- Jul 21, 2006
- 2,761
Two different things here.
The MAF wiring issues mentioned earlier was regarding a possible wiring blunder by the manufacturer of the harness so just make sure your harness for the MAF has the correct wiring sequence. The colors I gave you are OEM so may or may not be the same as the manufacturer for your aftermarket harness. I know RJM pretty much keeps their colors stock.
As far as the EEC/o2 sensor fried trace thing, most of these aftermarket harnesses come with a provision to allow us to run either an auto or manual EEC (ex:A9P vs A9L). This provision is usually a plug inline in the harness that you configure based on the computer you are running. If you fail to configure the plug correctly, you run the risk of frying trace on the EEC board. This scenario has nothing to do with the MAF.
