My dad just called me and said that when it died on him today he checked for spark and wasn't getting anything, so I think it has to do with something with the dizzy, it's junkyard with a new TFI,
When it dies and has no spark, try disconnecting the SPOUT connector and see if it gets spark.
When the SPOUT (SPark OUT) connector is in place, the pulse from the distributor pickup is routed by the TFI to the EEC through the SPOUT wire. The EEC then determines the correct timing for the conditions and sends back the spark pulse to the TFI, which in turn grounds the coil and makes a spark.
But if the TFI sees no spark signal coming back from the EEC, it will fire the coil based on the pulses from the distributor. This is how the base timing is set.
So, if there is a wiring harness or EEC issue, you should get spark with the SPOUT pulled. If no spark with the spout pulled, then it could be several problems, including no power to the TFI. But, it should be local to the distributor/TFI.
