DJs74
- Apr 1, 2014
- 1,135
Now that my Bronco is finished (I know, they are really never finished) and I'm driving it more and more and enjoying myself immensely... I had a curve ball thrown at me the other evening! Usually I fly solo or have the Mrs. riding shotgun because the boys are always here and there & everywhere but the other evening we took a ride for ice cream and my youngest son (14 years old and weighs about 110 pounds) was riding in the rear seat and we noticed the most annoying rattle / squeak coming from the rear cargo area. At first I thought something had come loose underneath or maybe something was happening in the rear wheel area but the sound and pitch seemed to change with the road surface, turning left to right etc.
When we returned home I went on an immediate hunt underneath and in the wheel wells and there was nothing to be seen. The I got to thinking about my rear passenger and that this never happened until some weight was applied on the rear seat, so I hopped back there and started squirming around and sure enough, I was able to duplicate the noise! Hurray, right. Not! I still don't know where / what exactly it is. I thought maybe it was my leather seat covers squeaking on the seat frame but not - then I thought it might be the seat mounting feet on the tub floor - not. It seems the floor itself is making the noise between the seat and tailgate but I don't know why? Everything is tight, the seat is mounted tight to the floor and there is carpet and padded jute between the seat brackets and steel floor (I also applied bedliner roll on prior to the padding and carpet).
I am assuming the floor in just one piece / one thickness construction just like the floor of a truck bed. I never really did anything in that particular area during the restore but now I'm wondering if there might be material overlap (steel folded on steel) in that area? Can't see it from underneath due to the fuel tank / can't see it from inside due to the carpet.
what I know for sure: noise is generated somewhere between the seat and tailgate in the floor and it only does it when weight or someone is sitting on the rear seat so that leads me to believe that something between the seat and floor is up but everything looks normal underneath directly below the seat area. The one thing I had to do when I reinstalled the rear seat is use bolts and nuts because the factory welded on square nuts were gone somewhere prior to me but the floor was 100% solid. I always assumed that the PO simply wanted to take the seat out at some point and the bolt threads were corroded due to road grime exposure so they just cut them away and installed bolts / nuts
any ideas as to what this mystery noise could be is appreciated.
My next step will be to take the rear seat out, remove the carpet hold down strips, peel the carpet back and get in there to inspect
*Edit* I forgot to say, after we arrived home fresh off the ice cream run and after the initial inspection, I went for another ride solo and no noise. That's how I came to the conclusion that is was all driven by weight / force applied to the rear seat - strange...............
thanks,
DJs74
thanks,
DJs74
