migs' build thread - A 1970 Bronco ...an ever evolving project
tasker
all knowing of nothing
NH
better get cracking, only a couple days left! :cool:
migs
migs
well, going to take even longer now since Somebody decided to throw a Bronco event this saturday and take away from my Bronco wrenching time...:p;D
Slednut10
Guru? That's funny!
I'd say that's a great excuse for a wrench-a-que on Sunday.......;)
MR-CYN
NH
More wrenching and less interwebbingzzz! :)
Slednut10
Guru? That's funny!
Umm, why aren't there any pics of the C4 install???;D;D;D
tasker
NH
migs
migs
no, no c4 install... I think Art may have had an ulterior motive for delaying his exit.:-X
now, back on track. I owe a debt of gratitude to Art, Dave and Randy for making quick work of dropping the old greasy drivetrain out saturday morning. thanks, it's much easier to push the bronco around the garage now!;D
Oh, and thanks again Dave for droping by last week and helping install my ball joints, finally able to get started on my steering. more on that later...
migs
migs
Ok, so now that I finally have the knuckles ready I could get started on my TRO steering mock up. I am using the one ton kit from ruffstuff. so to begin I attempted to swap in my power steering box only to find that I needed to cut out a bit of the bottom lip of the radiator support(I'll deal with that later).
then with that in place you can see my impromptu "jig" for making sure I had everything in the right place so I could take my measurements for cutting the tubing.
everything went together fairly smooth and nothing binds when moving the axle up and down, left and right.
so far I'm pleased with the results and now I can start fabing up my track bar and brackets.
migs
migs
thanks guys, was a pleasure hosting!
track bar fab work almost done... I made a riser bracket that mounts snug over the original track bar mount and will be welded on when complete. I still have to make a few more pieces to box in around the heim joint, but for now wanted to make sure what I had so far was good.
please excuse all the washers and oddball spacers holding things on for testing.;D
I also made a couple pieces to reinforce the track bar mount at the frame, they will be welded on tying it into the frame better and making it about 3/8" thick on either side.
Crawdad
Hey buddy, my plane broke down in TN so I have 24hrs to sit around and watch your build! I like that riser bracket, might get one of those off ya when I begin work on my front axle.
migs
migs
flexes well and the up travel worked out well even with the straight track bar and riser on the axle, it just starts to kiss the oil pan when the duff arms hit the frame. so when I set my limits all will be good.
migs
migs
Bummer dude! sorry I don't have more to keep you occupied...
migs
migs
finished designing the rest of the components for the riser bracket, made them and welded it all up. seems like it should work out well and so far I'm pleased with the results.
fatboy
Glad to be here.
New Hampshire
Well life just ain't fair, you got all this talent, and I got none! ;D
It is truly a joy to see your fab work B! :cool::cool::cool:
