Hi - I have been having trouble with hard starts (and no starts) after the engine reaches operating temperature. Wait long enough and it will start. I have been reading on the boards and come to the conclusion that it might be due to the starter getting too hot and not having the opportunity to cool down so I thought it would make sense to install a higher powered mini starter - think i bought it from Toms. I also took the opportunity to replace the fender mounted solenoid and the post cables as well as the cable from the solenoid to the starter.
i had unhooked the negative cable from its post. However I did not move it far enough out of the way, and during the process, the cable made contact with the negative post - and I got a few seconds of connection that seemed pretty significant. i continued the install and believe i got everything hooked up right but am a novice so maybe didnt.
Anyway - when i had everything reconnected, I turned the key and got nothing... zip... zilch. Im hopeful that I only connected something incorrectly, but am worried that the negative connection i made had a big impact. I have tested the reading at the battery post and the fender solenoid and am getting 12.6 at both. I have also checked the 5 fuses in the glove box and none seem damaged.
I signed up as a contributor and will post a few pictures of the solenoid as it is currently wired as soon as my status is updated - hopefully my issue is as simple as the fact i cant follow directions. In the interim, can you guys give me some ideas on how to check if my negative connection had a more sinister impact on things?
